Is drag's oil return line that bad?
Old Sep 30, 2001 | 05:27 PM
Etylorcen's Avatar
Default Is drag's oil return line that bad?
I've heard many times not to use drag's oil return line? Is it really that bad? Also if I should get a new one where can I get a steel braided one cheap?
Old Sep 30, 2001 | 05:33 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Is drag's oil return line that bad? (Etylorcen)
I wouldnt say it bad, but with a ss braided hose you can use the Earl fittings and it looks nice and has a good seal.
art
Old Sep 30, 2001 | 07:34 PM
Mikex25's Avatar
New User
Default Re: Is drag's oil return line that bad? (dc2jdmhonda)
you can buy SS braided lines and fittings from http://www.anplumbing.com, http://www.bakersprecsion.com, or http://www.jegs.com
Old Sep 30, 2001 | 07:36 PM
GSRwBOOST's Avatar
Yes it licks great green donkey dicks.. I' surprised they havn't been cited for stupidity for that one... LOL
Old Sep 30, 2001 | 11:18 PM
dustin's Avatar
Default Re: Is drag's oil return line that bad? (GSRwBOOST)
Drag's oil return "solution" consists of a piece of conduit and some garden hose
Old Oct 1, 2001 | 04:27 AM
MackSpeed-616's Avatar
Default Re: Is drag's oil return line that bad? (dustin)
the bright side is... if you ever need to do any electrical or yard work and home depot is closed... you can just hit up the car and get any parts you might need
Old Oct 1, 2001 | 04:50 AM
maxim's Avatar
Default Re: Is drag's oil return line that bad? (TurboR616)
hehehe...yard work
Old Oct 1, 2001 | 05:08 AM
MiraiZ's Avatar
Default Re: Is drag's oil return line that bad? (maxim_force)
ewe...I don't have DRAG but still opted for the steel hoses....looks awesome...should do the bulkhead fittings too!
Old Oct 1, 2001 | 02:30 PM
Etylorcen's Avatar
Default Re: Is drag's oil return line that bad? (Mikex25)
What size and length should I get?
Old Oct 1, 2001 | 02:44 PM
Flamenco-T's Avatar
for most, a foot is long enough, but I have been told might need up to 2"
Old Oct 1, 2001 | 02:45 PM
dustin's Avatar
Default Re: Is drag's oil return line that bad? (flamenco)
I bought 2 feet of it. I messed up on the first one (made it too short), so good thing I bought too much!
I just bought another 2 feet along with some "fyrejacket" stuff to go over it. My dump tube pushed the oil return line into the downpipe and 'browned' it a little bit... so I have decided to replace it and put that heat shielding over it.
Dustin
Old Oct 1, 2001 | 02:56 PM
93LSivic's Avatar
I got what you need.
https://honda-tech.com/zerothread?id=73258
Old Oct 1, 2001 | 03:03 PM
SiRkid's Avatar
Default Re: Is drag's oil return line that bad? (93LSivic)
what size line should i get???
BoostinDC2's Avatar
i would upgrade. my first turbo didnt last me that long. the small tube that they give you kinks so easy
Old Oct 1, 2001 | 03:07 PM
liam821's Avatar
25 Year Member
Default Re: Is drag's oil return line that bad? (BoostinDC2)
i used some garden hose (the $30/foot stuff) and some water pipes from home depot to make mine..
liam
Old Oct 1, 2001 | 03:15 PM
dustin's Avatar
Default Re: Is drag's oil return line that bad? (SiRkid)
It depends on the size of your fittings... but -10 AN is a good size.
Dustin
Old Oct 1, 2001 | 04:05 PM
DragII's Avatar
25 Year Member
YES!
I did the earls, SS thing worked GREAT
Old Oct 1, 2001 | 05:36 PM
chri5's Avatar
Default Re: Is drag's oil return line that bad? (DragIIcivic)
err wrong pics before
[Modified by Chris_Turbo, 11:34 PM 10/1/2001]
[Modified by Chris_Turbo, 11:55 PM 10/1/2001]
DragII's Avatar
25 Year Member
Default Re: Is drag's oil return line that bad? (Chris_Turbo)
Old Oct 1, 2001 | 06:29 PM
dustin's Avatar
The only thing you want in that picture is the line.
You do not want that blue top fitting.. where would that even go?
And the bottom thing in the picture is just one of those show "hose ends" that still uses a cheapie hose clamp.
Dustin
Old Oct 15, 2001 | 12:24 PM
Etylorcen's Avatar
What kind of fitting should I get? Should I just use the drag fitting and a different steel braided line?
philafelman
Nov 4, 2009 06:21 PM
Black R
Feb 20, 2005 03:12 PM
reignofchaos
Jul 27, 2003 10:34 AM
queez
Mar 31, 2003 03:01 PM
DamonBoost
Oct 24, 2001 12:11 AM
