Crank Pulley
Old Dec 30, 2002 | 05:41 PM
SupaFly_Honda's Avatar
Default Crank Pulley
I'm changing the water pump and all belts off a 95 Honda Accord, and I can't get the bolt that holds the crank pulley to come off. Do you guys know of any easier techniques of getting this bolt off? I've used my own air guns, took it to a local FireStone tire shop, and took it to a local truck stop and used there air guns but didn't do nothing. Can any of you guys help?
Old Dec 30, 2002 | 05:47 PM
sackdz's Avatar
Default Re: Crank Pulley (SupaFly_Honda)
I'm in the same boat as you. Air tools didn't work for me either. Moroso and others make a crank pulley holder wrench. The center of the pulley is a socket head and you hold the pulley while you loosen the bolt with a breaker bar. I should pick one up one of these days...
Old Dec 30, 2002 | 05:53 PM
Default Re: Crank Pulley (sackdz)
I just picked up one of those hex tool today. Used it for about 30 mins, and works fine but that damn bolt is just too tight! I'll keep on tring tomorrow.
Old Dec 30, 2002 | 06:08 PM
Cory man's Avatar
The easiest thing to do, take it to a local garage and have them break it free. Tighten it by hand and drive home. I have a local guy that charges me $5. Best $5 I spent.
Old Dec 30, 2002 | 06:41 PM
Chiovnidca's Avatar
Crank pulley holder and a breaker bar.
Old Dec 30, 2002 | 07:19 PM
jweller's Avatar
Default Re: Crank Pulley (Chiovnidca)
A diary of my woes
https://honda-tech.com/zerothread?id=328470
ended up paying the corner garage a few bucks to break it loose
Old Dec 30, 2002 | 08:37 PM
qwklude82's Avatar
Default Re: Crank Pulley (jweller)
hey where can you get one of those hex tools(pulley holder)? Can we rent one from a local auto parts store?
Old Dec 31, 2002 | 05:40 AM
94CivicSi's Avatar
Default Re: Crank Pulley (qwklude82)
you can search around for the hex tool. I shopped around online and got one for about $30. WELL worth it!
I had previously used the method where you remove the cluth access cover and stick something in the ring gear of the flywheel. Worked well but it was a lot more work. It's tough to get to all the bolts with the header on and with SOHC VTEC's, you've also got to remove the engine braces between the block and tranny.
One the motor is "blocked", slide and 8ft section of tube (chain link fence post will do) over your breaker bar and bust that biatch loose. I tried a number of air and power guns and never found one that could do the job.
[Modified by 94CivicSi, 6:41 AM 12/31/2002]
Old Jan 15, 2003 | 02:57 PM
Brohamcivics's Avatar
Default Re: Crank Pulley (94CivicSi)
What are the chances of bustig the bolt going into the crank pulley?
Old Jan 15, 2003 | 03:01 PM
turbohonda's Avatar
Default Re: Crank Pulley (Brohamcivics)
Get a Matco 3/4 drive impact airgun with 175 psi air pressure and they always come off.
[Modified by turbohonda, 5:10 PM 1/15/2003]
Old Jan 15, 2003 | 03:42 PM
tominos's Avatar
Default Re: Crank Pulley (turbohonda)
breaking the bolt? i dunno, but it's torqued on there to 132 ft. lbs.
Old Jan 15, 2003 | 03:49 PM
Chiovnidca's Avatar
I've only seen one break, and that was going back on. (I didn't do it.)
Old Jan 15, 2003 | 03:58 PM
Kamin's Avatar
Moroso crank pulley holder
best 65$ ive ever spend (next to my helms)
[Modified by Kamin, 4:58 PM 1/15/2003]
Quiz's Avatar
Default Re: Crank Pulley (Cory man)
For those without a garage or the tools to remove it, this^ is your best advise. I have had problems with air tools. I have a 1/2 inch drive 19mm impact (they don't make a 3/4 drive 19mm that i've seen) socket welded to a 3/4 inch drive extension and 3/4 inch breaker bar and it's still a bitch to get off.
Old Jan 15, 2003 | 04:13 PM
WhiteDSM520's Avatar
Yank the starter off and wedge a big flathead between the teeth and press it against the tranny. It always works for me and my friends. I don't know how accessable the starter is on an accord though. But I HTH.
Old Jan 15, 2003 | 04:56 PM
1fasttoy's Avatar
Default Re: Crank Pulley (WhiteDSM520)
Have you tried any head on this yet? This will help free most of them up. The right tools work the best, but sometimes you have to work with what you got.
Old Jan 15, 2003 | 07:10 PM
Shawn C's Avatar
In The Garage
Default Re: Crank Pulley (1fasttoy)
have you tried tightening it up with the impact, then loosening?? normally, if you tighten, loosen, tighten, loosen, etc., it will break loose.
Old Jan 15, 2003 | 07:35 PM
trbob16a's Avatar
Default Re: Crank Pulley (22lbGS-R)
Go to home depot and buy a 5 ft extension steel plumbing pipe. Give it everything you have. It'll come loose.
If you can pull on it a measily 100 ft lbs, which you should be able to, you'll be putting 500 ft lbs of torque on it. Try bouncing it some too to break it free. This process should take you less than 5 minutes.
Old Jan 15, 2003 | 10:38 PM
shortyz's Avatar
Default Re: Crank Pulley (trbob16a)
yep get a decent extension or you will twist it off like butter and use a 5 foot pole.
also i think all air guns are rated at 120psi. if you run them at 175 for to long u wreck the flappers or something inside them.
i want the 600$ 1" impact 2000 ft lbs
Max torque 2,000 lbs
CFM 90 psi
forward/reverse
WT 22 lbs
Reversible side handle
1/2" Air inlet
For Max power use a 3/4" air line
Pull the trigger and hang on!
Powered By Garrett
19
Jul 20, 2008 05:17 PM
jokr78
May 26, 2005 09:18 AM
93gsrcoupe
Sep 30, 2004 09:54 PM
importneeds
Mar 17, 2002 04:20 PM
ManinCamo
Jan 1, 2002 09:58 AM
