How many degrees retard? D16 AFC Hack 9.7:1 compression
No BTM just using the old distributor and 8lbs of boost.
3 degrees? To compensate for elec. adv. since i am using AFC hack
[Modified by BorderM3, 5:03 PM 12/30/2002]
TTT common ladies...i know there is talk about the AFC 'Hack' every 5 minutes someones gotta have a recommendation here
I remember a post showing the timing with afc hack vs hondata and with 4 degrees retard the maps were closest. I would do 4 at the distributer although youll be slower off boost, it will be safer.
well, it depends on how much boost you're running. for like 6-8psi I think stock timing is fine. I run stock timing on 6.5psi and i know of people that ran up to 8psi on stock timing. Personally I think anything over 8 u should retard the timing. but personally I wouldn't run over 10psi on the hack anyway.
_______
_______
