why wheels hops rather than torque steer???
Old Dec 30, 2002 | 10:22 AM
scsi's Avatar
Default why wheels hops rather than torque steer???
I got a JRSC, my front wheels hops pretty bad....when i rev. it pretty high...even on third gear? I drove a GSR and it just torque steer....hmmmm....does it got anything to do with wheel set up. I have a Rota 15"....only 12lbs....is this a factor? Thanks
Old Dec 30, 2002 | 10:44 AM
civicrr's Avatar
Default Re: why wheels hops rather than torque steer??? (scsi)
Has to do with tires getting grip & then sliping, then gripping,etc. Wheels are not really a factor. Movement (suspension, engine mounts, axles) is the problem.
Good shocks? Broken engine mounts? ES engine mounts work great for this problem. I would try them first since they are the cheapest. There are also lower arm braces that you could get which brace for fore/aft movement. I have no info on those. You might want to try the drag racing forum.
added in edit: not to say you are not welcome here. just saying they might have more info on the lower arm braces there.
[Modified by civicrr, 11:45 AM 12/30/2002]
[Modified by civicrr, 11:47 AM 12/30/2002]
Old Dec 30, 2002 | 10:45 AM
turbosol's Avatar
Have you ever tried motor mount inserts, they help alot with wheel hop. Strut mount bushings are also supposed to help.
Old Dec 30, 2002 | 11:48 AM
Overblown-Teg's Avatar
Default Re: why wheels hops rather than torque steer??? (turbosol)
I have insane wheel hop on my na gsr.. I changed to urethane engine mounts and it help alot.. doesn't feel like the engine is tearing out on every shift now. I still have bad wheel hop though. Will traction bars fix this? I was looking into a set of the jim fab bars.. I just want to know the best way to fix it.. Will lowering the car with stiffer springs help?
siriussr
12
Apr 15, 2009 10:56 AM
wfocrx
Nov 21, 2007 12:18 PM
jivi
Honda Civic (2001 - 2005)
May 20, 2007 07:40 AM
brookliner7
25
Mar 3, 2005 06:29 PM
kani
12
Sep 23, 2004 11:41 AM
