whats the best way to power up accessories?
Old Dec 26, 2002 | 01:21 PM
gsrstyle's Avatar
Default whats the best way to power up accessories?
ok so far i have been told the best way to power accessories is : to run of the battery w/ a inline fuse, take a male spade connector connect it to a open slot in the fuse box, and take the metal ends of the wire and wrap it around 1 arm of the fuse then plug in the fuse.
i was also told to tap? in to a wire using a t-tap (ex cigarette lighter), but when i tried that i kept popping fuses.
Old Dec 26, 2002 | 03:59 PM
integra-modder's Avatar
Default Re: whats the best way to power up accessories? (gsrstyle)
You keep poping fuses because you probably put it after the fuse rather than before (in terms of the current flow).
This is what I suggest you do. The fartest most empty open pin on our fuse boxes is clea +12 from the batter. What you do is get a wire to go from that pin, to another ATC Fuse Block that is avaliable at any pepboys, autozone, etc. for around 7 or 8 bucks. Most hold 6 fuses. It has a power in point, and then 6 fuses, and 6 spades to connect your wires to.
This is what I use to hook up all incar electronics, and mount this thing where its easily accessible.
Old Dec 26, 2002 | 06:11 PM
gsrstyle's Avatar
Default Re: whats the best way to power up accessories? (integra-modder)
are you talking about the open slots under the dash? or under the hood? or couldnt i just power the atc fuse box by running a wire to the battery?
Old Dec 27, 2002 | 12:29 PM
in the under dash fuse box. there are slot that connectors fit in above the fuses.
Old Dec 30, 2002 | 01:01 PM
Check out this picture, its the A slot. That slot has a constant 12+ from the battery.
[Modified by integra-modder, 5:03 PM 12/30/2002]
Old Oct 12, 2003 | 09:10 AM
model x's Avatar
is that +12V fused?
How much current can we pull from that circuit before we burn stuff?
Old Oct 12, 2003 | 08:36 PM
Default Re: whats the best way to power up accessories? (model x)
I believe its refered to as +B in the Helms manual. However, the fusebox has a 40 amp (I beleive, not 100% sure) fuse, its one of the larger square ones that is in the under hood fuse box.
Old Oct 13, 2003 | 07:16 AM
model x's Avatar
So as long as we don't draw more than 40amps we're good. Well that sounds pretty good. I'm gonna pick a distribution block tomorrow
Old Oct 13, 2003 | 03:42 PM
I have 3 distributor blocks running in my car, 2 for alarm and 1 for all my electronics and what not.
Just make sure you find a good easily accesible location that is a sturdy point to secure to, or else it gets nasty.
Thepowderblue
May 23, 2012 02:30 PM
superfuji57
Jul 30, 2004 12:02 AM
cd5_2NR
Audio / Security / Video
Jul 1, 2004 01:38 PM
PatrickGSR94
Apr 6, 2003 05:46 PM
Halo
Dec 28, 2001 01:28 PM
