Electrical issue
Old May 18, 2012 | 01:08 PM
Thepowderblue's Avatar
Default Electrical issue
So I bought the car and that wire was there. It wont run and power wont go to anything with out having that jumper wire there. As you can see it can get pretty hot, It melted the rubber off itsself.
By thepowderblue at 2012-05-18
Old May 20, 2012 | 03:22 AM
Lost Again's Avatar
Default Re: Electrical issue
Fire, fire, fire........
Can you test the fuse.
I'm trying to figure why the ELD is being used....what year is this?
Old May 20, 2012 | 12:09 PM
redbull-1's Avatar
Well, for one thing one end of the wire is connected to is the battery fuse. Appears to be bypassing the fuse in the circuit. If the fuse was blown, the car won't start, etc.
That is a very dangerous looking hack job.
Old May 20, 2012 | 01:48 PM
The fuse is good. Its on a 91.
Old May 20, 2012 | 04:26 PM
jdmcertified909's Avatar
i would say pull the fuse box off and find out why your not getting power to the other side of the fuse. if the fuse is good and still wont light up and turn on then its obvious your not getting power to one side of the fuse
Old May 20, 2012 | 06:15 PM
redbull-1's Avatar
I would say it is either a problem with the ELD (which is part of the fuse/relay box) or the ignition power circuit (as I don't see a Blk/Yel wire (ignition power) going into the ELD.
Old May 21, 2012 | 12:27 AM
That wire is not going to that plug. it gos from that metal thing to the battery fuse not that plug like it looks.
Old May 22, 2012 | 04:08 PM
Lost Again's Avatar
PLEASE test the fuse?
Old May 23, 2012 | 02:30 PM
replaced it
CheddarPopcorn
Jun 30, 2009 10:53 AM
Gvis420
Sep 18, 2008 06:28 AM
AkA_JackRisom
Feb 27, 2006 09:28 PM
cd5_2NR
Audio / Security / Video
Jul 1, 2004 01:38 PM
PatrickGSR94
Apr 6, 2003 05:46 PM
