Noticeable difference between .63 A/R stage 2 vs stage 3? (for an H22)
Old Dec 26, 2002 | 11:57 AM
BlueShadow's Avatar
Default Noticeable difference between .63 A/R stage 2 vs stage 3? (for an H22)
Hi guys,
I'm thinking about swapping out my T3 0.63 a/r stage 2 turbine for a stage 3 turbine. will there be a noticeable difference between the two stages?
IIRC the difference in stages is the diameter of the turbine and the opening right? BTW this is for an H22 which will be boosting at 7 PSI at first then eventually 10 PSI (daily) and 15 PSI (track) once it's been built.
TIA
Old Dec 26, 2002 | 12:11 PM
boosted3g's Avatar
Default Re: Noticeable difference between .63 A/R stage 2 vs stage 3? (BlueShadow)
youll definantly want the stage 3. If you have a big compressor wheel like a 60-1 i would even recommend a stage 5.
Old Dec 26, 2002 | 12:28 PM
BlueShadow's Avatar
Default Re: Noticeable difference between .63 A/R stage 2 vs stage 3? (boosted3g)
I have a T04E 60" compressor and I plan on sticking with that, but I bought the kit used and it came with the .63 stage 2 turbine (I wanted a stage 3).
90ZCREX
Jun 29, 2011 06:47 PM
Greyout
Aug 7, 2003 08:15 AM
Full-Race Geoff
Nov 18, 2002 11:31 AM
txhatch
Jan 24, 2002 11:42 AM
