Question about valve seals?
Old Dec 26, 2002 | 11:16 AM
stupidfast's Avatar
Default Question about valve seals?
Would bad valve seals cause a loss in performance? I think my seals are going bad, it smokes a little too..
Old Dec 26, 2002 | 11:29 AM
myhatchrips's Avatar
Default Re: Question about valve seals? (stupidfast)
probably 5-10 hp lost depending on how quick your burn oil. how bad is it anyways?
Old Dec 27, 2002 | 05:57 AM
stupidfast's Avatar
Default Re: Question about valve seals? (myhatchrips)
One and a half quarts every oil change.. Not to bad.. Motor has 105,000 miles and I replaced all gaskets and new pistons and rings at 95,000.. Just forgot to do the valve seals while it was apart..
Old Dec 27, 2002 | 06:30 AM
Spade's Avatar
I suggest a compression test.
Old Dec 27, 2002 | 08:21 AM
Ricky Rojales's Avatar
Default Re: Question about valve seals? (Spade)
A leakdown test wouldn't hurt either.
Old Dec 27, 2002 | 04:04 PM
stupidfast's Avatar
Default Re: Question about valve seals? (Billy Ray Valentine)
my compression was 215-220 in all four cylinders, warm car, all wires removed, wot.,
Old Dec 27, 2002 | 06:00 PM
dr650's Avatar
New User
does the car has blue smoke coming out the tailpipe every morning or everything u first started the car?if yes ,then u need to replace valve seals.checked ur distributor o-ring might be leaking oil there.
FOR SALE!!!!!
bay area only<<<pick-up only<<i got this following stuff for sale:
92 ls motor /trany/ecu for $600 (rebuild motor trany no grinds)
93 prelude motor/trany/ecu for $1000(h23)(motor has 148000 mlz/trany no grind/still good compresion/needs water pump)
95 si trany for $200(no grinds)
92 ys1 trany for $400(da gsr)no grinds
92 integra trany for $200(no grinds)
94 si motor for $250(100000+ mlz)needs head gasket
pwo ecu for $100
cr/vtec motor for $1600. still in the car.no leaks.(b16 head /jdm b20z)
91 integra ls for sale >>$2500 210000+mls.
Old Dec 28, 2002 | 07:19 AM
cool. mine was at 230 230 225 230. good numbers
hondamatt89
Mar 17, 2015 11:19 AM
G3teg96
Aug 20, 2011 05:00 PM
t00JDM
Oct 21, 2010 12:48 PM
RacerRex
Dec 2, 2006 05:19 PM
DANG YO
Nov 24, 2003 04:26 AM
