TurboXS High Performanc BC. Quick question.
I was following thru the intructions that the BC came with and eventually, have gone to the point where it needs to be pre-setted by adjusting the coarse adjusting screw (3 full turns) before adjusting the fine adjusting screw.
Now going onto adjusting the fine adjusting screw. It tells you to do 3 turns counter clockwise and will increase boost by approximately 1 - 3 psi.
Question:
Does that mean, 1 -3 psi ontop to what the preset boost level on the wastegate? This is into an internal wastegate btw.
I'm a little bit skeptic and would like to know things like these as a pre-caution.
Question:
i think you got the screws mixed up. the fine adjustment screw is in the brass part. the coarse adjustment screw is at the top.
[Modified by Bottoz, 7:29 AM 12/26/2002]
Christmas gift, Ray?
Well guys... it's in and boosting 2 more psi than my current boost level and it's set to 8.8psi (.6bar). Still have the blue box installed if anyone cares. I only had to adjust it twice to get the set level of boost that I want and 'am very please at this point. It holds boost exactly @ .6 bar especially on high speeds... 3rd, 4th, 5th gears were all steady @ .6 bar. I love it!
I boosted up to 12psi (.8 bar)
today and that was scary. No traction. LoL!
reignofchaos
Sep 24, 2003 06:56 PM
