d15b2 vs d16a6 block.
now to my knowledge the only differance betweeen d15b2 and d16a6 is the DPFI vs MPFI.
now are the block identical and if they are why did honda stamp them with differant codes. if i was just using HEAD down would it produce the same power as the d16a6?
I'll add that I ran a D16A6 block with a DX head and cam on my MPFI. I was using a homemade turbo kit pushing 5psi. I drove the **** out of it for 3 months. burn't 2 cluthes and then spun 3 bearings. That motor had new rings but 185k miles on the bearings. I'm now running the D15B2 with new rings and rod bearings and it sees many trips in the red. It runs strong. I aslo picked up 3 more D15's for about 200 and all have good cranks and blocks.
i wonder if alot people will ever decide to buy sohc engines, like the d15 and fix them up and then i wonder how highthe price will go if they are in demand...
While we're on the subject of D15's, you guys heard of that Bisi guy running 10's all motor on his D15? Crap i never knew they had that in them...of course its a full drag crx tho, but ****...
shiet my swapped out d16a6 crx motor was sitting in my backyard for weeks. so we took off the tranny and intake manifold, loaded it on the truck and grabbed my friends d15 from his DX and tossed them at the local pick and pull. i tried to sell it but bunch of flakes and even had an offer for $60 for BOTH motors! now they're gone... too bad i didn't see this thread earlier. with all the d series getting swapped out, i wouldnt' mind doing a d series project.
Bisi's car was bored and sleeved nothing else. Actually displacement was like 1535 (I believe) Mista Bone would know more about it. Bisi is a member here now too.
the d16a uses a diff crankshaft and rods the bore and stroke on d16a6 is 2.95x3.54 and the compression on a6 is 9.1 and d15b1&2 are 2.95x3.33 compression is 9.2 except 88b1 has 9.6cr..so i guess a a6 is like a stroked b15
bisi's motors is 1529cc
so how much can a stock d16a6 bottom end hold also with the stock d15b2 bottom end???
http://www.turboclutch.com/jrhonda.htm
that must be one mean head hes got on that motor if the bottom isn't too modded out. Im sure hes got a crazy compression ratio. though i don't know. He probaby went for that 1.75 ratio of horizontal to vertical distance which is said to be the best to produce the least amount of stress that's put on the rods with any given setup...thouogh i could be wrong because i don't know how you go about setting up the whole thing
[Modified by altoid, 11:55 PM 12/29/2002]
