Turbo oil feed hardlines??? anyone???
Old Dec 23, 2002 | 12:04 PM
DIY_Racing's Avatar
Default Turbo oil feed hardlines??? anyone???
Im a little skeptical about running SS lines to my turbo.. I want something super durable, inexpensive, and somewhat stock looking... I want to run a hardline to my turbo oil feed.
anyone done this?? whats involved???
Old Dec 23, 2002 | 12:07 PM
RAWB's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (DIY_Racing)
I'm using tephlon tubing inside a stainless steel braided line. Just go to a local fittings store, get about 5 ft(only ran $4/ft) and a couple of compression fitting($5 each).
Not exactly stock looking, but for $30 you have perfectly durable lines- been runnin over 2 years, no probs
[Modified by integracon, 1:08 PM 12/23/2002]
Old Dec 23, 2002 | 12:23 PM
DIY_Racing's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (integracon)
well, i dont like the big SS line ziptied to other ****.. ya know???? is there any better way to run one??? you have any pics???
Old Dec 23, 2002 | 01:09 PM
mos's Avatar
mos
I was contemplating this breifly also, but just decided to go braided SS anyways, because I found a cheap source. I understand your need to not have blingin things under your hood. I feel the same way. Theres no reason you could not run a hard line. Go for it.
Old Dec 23, 2002 | 04:23 PM
Hispeed's Avatar
I have a friend that is in the mist of completeing his project and he ran hard lines to his turbo. Looks really really nice I might add. I will try to get some pics soon.
Old Dec 23, 2002 | 05:29 PM
shortyz's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (GSRev)
i almost posted the exact same thing last week on here before i hit cancel cause i thought i was being a retard
go for it. i wanna see em when there done!
Old Dec 23, 2002 | 06:16 PM
Jefnes's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (shortyz)
Goto HOME DEPOT.
Get small copper tubing. Bending tool, and Flaring tool for the ends.
easily withstands your running oil pressure.
I have seen this done on several 'backyard' jobs...
Works quite well.
Jeffrey Atwood
Old Dec 23, 2002 | 06:19 PM
DIY_Racing's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (Jefnes)
so would having hardlines be considered bad? or ghetto??? i thought it would be more reliable....and better then running a line all ziptied to something else ya know...
anyone have any pics of either a hardline setup or regular SS line... i want something that looks nice..
Old Dec 23, 2002 | 07:19 PM
shortyz's Avatar
so you would need a BSPT to NPT 1/8 fitting for the back of the block and a whatever u call those..
the harlined it flared with a little nut thing and it screws onto some kind of brass fitting. anyone know the name?
Old Dec 23, 2002 | 09:48 PM
project dc2's Avatar
amstreetrod.com
get 4 feet of the speed flex hose, its only 20$ its stianless steel braided and its good **** !
Old Dec 23, 2002 | 10:01 PM
Flamenco-T's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (project dc2)
all -3 lines are teflon coated unlike the larger ones ( -4 and larger)
any -3 lines will work...
ALL speed flex lines are all teflon coated, therefore more expensive, they are designed primarily for fuel to reduce the fuel vapor, you also need to use speed flex hose ends, due to the exact inside diameter of the hose.
oooh about the hard lines for oil feed, stick it to something simple that has been proven for years.....a lot of DSM guys that I know, switch to stainless braided lines, since the stock hard liens bend and etc...
stan
Old Dec 23, 2002 | 11:09 PM
shortyz's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (Flamenco-T)
i can see that hapening
so whose got an oil line kit for sale?
Old Dec 23, 2002 | 11:21 PM
stan
at amstreetrod you can buy them with the swivel seal fittings attached already for only 20$ !!!!
Old Dec 23, 2002 | 11:56 PM
RICE POLICE SIP's Avatar
well what i did is..... i got the SS braided line and ran it from the back of the block, down and underneath the block,(in the hump of the oil pan) then up and to the turbo... you can see the line at all....
Old Dec 24, 2002 | 06:19 AM
T25 civic's Avatar
Default Re: Turbo oil feed hardlines??? anyone??? (92boostn'hatch)
Does that bother anything running it like that?
It would seem to but I can't think of what lol Its to early for me and I'm all hungover, maybe I should goto bed.
Nick
My JDM EJ8
Dec 30, 2008 06:57 PM
turboH22Aakkord
Mar 27, 2005 05:55 PM
PrecisionH23a
Sep 13, 2003 07:20 PM
Snafu-Si
Jul 2, 2002 07:58 AM
SlowB16
Mar 7, 2002 03:26 PM
