Is it a bad idea to use this line for vac?
Old Dec 22, 2002 | 12:23 PM
B18EG6's Avatar
Default Is it a bad idea to use this line for vac?
is it a bad idea to use the line coming off the cracnkcase ventillation thing for a vac line?
I will go take a picture so you know which one im talking about
Old Dec 22, 2002 | 12:26 PM
JM Performance's Avatar
Default Re: Is it a bad idea to use this line for vac? (B18EG6)
honostly, i dont see how it could hurt.....but no one really does it....just pick a different one. if you want a big one, use teh one before the brake booster.
Old Dec 22, 2002 | 12:29 PM
B18EG6's Avatar
Default Re: Is it a bad idea to use this line for vac? (00SilverLS)
yeh, I used the brake booster line for the BOV, and I wanna use the line i just referred to for the wastegate, and boost gauge. I realize the vapors from the block, and maybe oil??? will go through that line...didnt know if it would mess antything up
Old Dec 23, 2002 | 12:25 PM
b18cya's Avatar
if you have an FI setup, you shouldn't be pressurizing the head.
Old Dec 27, 2002 | 11:53 AM
B18EG6's Avatar
Default Re: Is it a bad idea to use this line for vac? (b18cya)
wait, what?
Old Dec 27, 2002 | 12:01 PM
93LSivic's Avatar
I wouldnt use it. Think about it.....crankcase ventilation contains oil vapors. Do you really want oil getting into your wastegate?
Use the brake booster line, that is the best one.
Old Dec 27, 2002 | 12:19 PM
B18EG6's Avatar
Default Re: Is it a bad idea to use this line for vac? (93LSivic)
Is it bad to run the wastegate and bov off the brake booster?
maxogsr
Feb 18, 2010 09:54 AM
jdm_dc_199
Sep 10, 2007 11:31 PM
Del_Slowest
Oct 22, 2003 03:48 AM
Integra_Boi
Aug 13, 2002 02:10 AM
zerofourLS-T
Jun 20, 2002 10:33 PM
