AN Brake Fitting Question
Old Sep 10, 2007 | 09:27 AM
jdm_dc_199's Avatar
Default AN Brake Fitting Question
how do i know what size fitting to go with for my Brake Master Cylinder?(-3AN, -6AN, -8AN, ect.) i was planning on replacing all my brake lines w/ steel braided lines and earl fittings. iv tried searching, but no luck. thanks for any input.
Old Sep 10, 2007 | 09:59 AM
IN VTEC's Avatar
Default Re: AN Brake Fitting Question (jdm_dc_199)
Don't use braided line, use steel hardlines. Use no bigger than -3AN.
Old Sep 10, 2007 | 11:17 AM
havok hybrid's Avatar
Threre is a unique fitting for you master cyliner.. You need a 1.25mm x 10.0 thread pitch
just go to a fitting store and tell them what your doing . There is only a 12.0 and a 10.0 fitting..
They are not AN fittings.!!!
Old Sep 10, 2007 | 03:14 PM
dwolsten's Avatar
Default Re: AN Brake Fitting Question (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Don't use braided line, use steel hardlines. Use no bigger than -3AN.</TD></TR></TABLE>
Better yet, use stainless steel hardlines, and polish them. Make sure to get seamless lines so you don't have any leak problems. Use 3/16" hardlines, single-flare them at 45 degrees, and reuse the stock fittings (though nickel-plated fittings would look great, if you can find them in this metric size).
Old Sep 10, 2007 | 11:31 PM
jdm_dc_199's Avatar
thanks for all of your input. so i think i might go with dwolsten's suggestion. just use stock fittings and go w/ stainless steel lines.
do you know where would be the best place to get the lines that are a reasonable price?
Corksil
46
Jan 21, 2012 07:44 PM
maxogsr
Feb 18, 2010 09:54 AM
chris3385
Mar 25, 2009 11:21 PM
Soda Popinski
Dec 31, 2005 12:28 PM
just a honda
Apr 4, 2004 07:10 PM
