Where to "T" my BOV and wastegate off???
New User
I used to have these 2 vacume based factors running off my main PCV, which i found wasn't teh best place for them. where should i T them off???
i don want to use the line directly to the left of the PCV because i have many things running off that already.
i know this is kind of a beginner question but i would appriciate all that have any input.
thank you
thank you
New User
Re: Where to "T" my BOV and wastegate off??? (CovertFI)
off that line i have my boost gauge and map sensor/check valves coming off it already. do you think it would be ok to splice more vaume off it.
i heard it you put too many things off one sourse..youo loose vacume pressure.
Re: Where to "T" my BOV and wastegate off??? (zerofourLS-T)
i dont know what the ls mani looks like but just t off of any line comming from the mani and you will be fine.
Just trace the line from your brake booster. You know where that is right? not being a dick just asking... HTH
Rob
Rob
you know where the master cylinder is? The thing where you pour in brake fluid? The booster is the round black thing mounted to the firewall. There should be a vaccum line from there to the top of your intake manifold about 1/2" in dameter
Re: Where to "T" my BOV and wastegate off??? (Slow_ass_4dr)
The Brake booster has a 3/8" line. (At least that's what kind of vacuum T you will need to use on it.)
Heres a picture of the line in my car.
