Enkei Miata rims on civic?
Well, some Miata wheels have a hub-center hole that is too small for the
hub register (where the axle nut is).
So on those wheesl you need to have a machine shop bore it out to clear this hub register.
Not sure if aftermarket wheels will be hubcentric for Miatas... if not they should be a bolt on affair... you can check it easily, remove one of your wheels, measure the hub register diameter, ask the seller to measure the inside diameter of the wheels hub-center hole.
hub register (where the axle nut is).So on those wheesl you need to have a machine shop bore it out to clear this hub register.
miata never came with 6.5", but rather with 5.5-6" in 14" wheel.
mazda hub diameter is about 53mm while H/A share 56mm hub size. so as tated above boring out about 4mm of the wheel is required . other then that the wheels are 4x100, 45 offset and very lightweight.
http://www.miata.net/faq/wheel_weights.html
The_Head
Nov 14, 2006 03:53 PM
