Need second opinions on Oil return line location
I was told where my turbo return line enters the oil pan is too low. I was told the oil wouldnt drain from the turbo and would go through the seals and burn in the turbine. Let me know what you think. Should I relocate the hole so it is higher up on the pan?
OT: Heres a pic of my beater car I just picked up. Pretty nice eh?
How much higher should it go?
I was told to put it as high as possible, almost up against the lip of the oil pan.
and what about the Moroso pans? Their return location is at a similar height as mine. That was our model.
btw this is a dumb thing to say....but make sure you dont weld the fitting on right beneath a bolt, that wouldnt be good. I only say this because I almost did
this is a good height
The DRAG oil return line blows ditch it and get the earl fittings or somthing similar.
go here for part numbers for the fittings - https://honda-tech.com/zerothread?id=232145
[Modified by BVM, 5:04 PM 12/13/2002]
