can i use OEM headgasket with 81.5mm bore ??
Old Dec 12, 2002 | 05:18 PM
Cyber ITR's Avatar
Default can i use OEM headgasket with 81.5mm bore ??
as the topic says
will be able to use it ???
thanks guys
Old Dec 12, 2002 | 05:32 PM
hondaswaper's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (VTEC_SiR)
yes
Old Nov 16, 2005 | 02:04 AM
ultradx's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (C-Westin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-Westin &raquo;</TD></TR><TR><TD CLASS="quote">as the topic says
thanks guys </TD></TR></TABLE>
That means you can run a stock bore(81.0mm) headgasket on a block with a 81.5mm bore?
I need to know this too.
Old Nov 16, 2005 | 05:57 AM
simike's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (ultradx)
Yes
Old Nov 16, 2005 | 06:55 AM
mike1114's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (simike)
U can run 81 MM gasket all the way up before 82mm.
Then an 82MM can almost go to 83MM and so on.....
I called Golden Eagle to verify this recently.
Old Nov 16, 2005 | 07:08 AM
D-tuned's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (mike1114)
the stock honda headgasket is 82mm
Old Nov 16, 2005 | 11:09 AM
ultradx's Avatar
Default Re: can i use OEM headgasket with 81.5mm bore ?? (D-tuned)
thanx for the input.
Old Nov 16, 2005 | 11:37 AM
cuin9sec
Guest
Posts: n/a
Default Re: can i use OEM headgasket with 81.5mm bore ?? (hondaswaper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaswaper &raquo;</TD></TR><TR><TD CLASS="quote">yes </TD></TR></TABLE>
integraboosted
Oct 3, 2007 10:12 AM
Master23
Mar 8, 2006 01:18 PM
PogKai
Aug 29, 2005 09:26 AM
vtecb20coupe
Feb 11, 2004 08:04 AM
senpai
Jun 17, 2003 05:39 PM
