internal wastegate sucks
i got a greddy gsr kit and a beautiful 2.5" custom downpipe (writeup and pics coming soon)
i DISCONNECTED the actuator arm on my internal wastegate so the WG port is WIDE OPEN and i still hit 8psi and climbing FAST...probly hit 1bar no problem
exhaust is TOO free flowing.
so i can
1) add exhaust restriction
(but it would be quieter)
2) make the wastegate port larger (its a mitsu turbo and they do this for the DSM guys)
3) ? any other ideas?
so i can
(but it would be quieter)2) make the wastegate port larger (its a mitsu turbo and they do this for the DSM guys)
so i can
so i can
Weld the WG shut and then put a flang on your manifold for an external gate. Problem solved. Internal gates are evil. I had to do this to a 95 awd tsi I had for a while.
Smarter than you
damn joe that sucks. i have an idea but i know u dont want to hear it..
.................................................. .................................................. .......sddabuyskfsl............................... .........................................dsasgagti alwastegatesaggsag................................ .................................................. .................................................. .................................................. agsdgasinlinepromanifoldagssdga................... .................................................. .................................................. .................................................. ..............sagsadgaandprecisionturboasdggggasg. .................................................. .................................................. .................................................. ......................asggdsgandsell18gandmanifold sggggfsa.......................................... .................................................. .................................................
[Modified by DIRep972, 4:41 PM 12/12/2002]
hey guys i suddenly had this idea to get an inlinepro manifold with tial and a precision turbo.
what do you think?
kidding. i am going to explore the ported wastegate setup.
what do you think?
kidding. i am going to explore the ported wastegate setup.Trending Topics
what do you think?
what do you think?
There used to be this place called Team Rip Engineering TRE that ported the wastegate hole and replaced the flapper with a larger one. Try searching for them on the net. They also did some crazy turbo porting.
You should check out forced performance. They do really good work with internally gated turbos (since they specialize in DSM mods) and could do a sick port on it as well. The owner, Robert, is a cool guy, too.
yusoslo
Apr 26, 2004 07:37 AM
