turbo a d series!?!?!?
Old Dec 12, 2002 | 02:54 PM
hakemjmba's Avatar
Default turbo a d series!?!?!?
well im planning to swap a d16y8 into my 93 del sol and i plan to tubo it with the rev hard stage 2c kit. what do you guys think of that. i know some people that turboed their d series and got a custom fit rev hard turbo and ran mid 12's (DnH) so would it be a good idea to turbo a d series, i jus want it nice and simple i dont really like the b series just because i dont have that kind of money if i turbo it and seems a little more complicated. so tell me what you guys think
Old Dec 12, 2002 | 02:55 PM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: turbo a d series!?!?!? (hakemjmba)
you`ll be fine. we can hold your hand if you are scared.
Old Dec 12, 2002 | 02:58 PM
gritsak's Avatar
Default Re: turbo a d series!?!?!? (vtecvoodoo)
hey vetcvoodoo...nice avatar
Old Dec 12, 2002 | 03:04 PM
IhateMy93BlackHatch's Avatar
I think u can run 12's if u do a rebuild on the motor and get the block sleeved so u can boost more than that stok 6 or 7Psi, i know someone who had the the Sohc greddy kit with the Rev hard manifold in a 90Si and was running 13.4 boosting 7psi on a stock motor (93 Sohc Vtec)
[Modified by IhateMy93BlackHatch, 12:05 AM 12/13/2002]
Old Dec 12, 2002 | 07:30 PM
tominos's Avatar
Default Re: turbo a d series!?!?!? (IhateMy93BlackHatch)
yes, i think the revhard kit is overkill on the puny d series. the t3/t4 turbo that comes with the kit is too big, and will have major turbo lag. get a small greddy turbo and boost away. oh yeah, build internals before planning to run 12s.
Old Dec 12, 2002 | 07:40 PM
Civichatch2k's Avatar
i think that it is a good idea if your money is tight. But isnt a turbo around the same price as a b16, personally i would go with b series but i have seen plenty of singles that are turbo'd and the run just as hard if not harder the b series. I guess it all really depends on the driver and the car but either way you are going to have good performance.
Old Dec 12, 2002 | 08:39 PM
Default Re: turbo a d series!?!?!? (tominos)
. the t3/t4 turbo that comes with the kit is too big, and will have major turbo lag. get a small greddy turbo and boost away. .
yeah you will run better with the smaller turbo becaue it will spool up a lot quicker, unless u wanna get a 50 shot of Nitrous with that rev hard kit then you'll be running 12's after u do a rebuild of the motor
Old Dec 12, 2002 | 08:46 PM
12SecHatch's Avatar
on my stock d16
13 psi daily,
stock internals
jsut thicker headgasket, to lower the compression
years later the motor finally went,
but years later,
fmax kit t3/t4
12.5@110
Old Dec 12, 2002 | 09:10 PM
Default Re: turbo a d series!?!?!? (12SecHatch)
Hey do you use the Greddy head gasket ? if not which one ?
Old Dec 12, 2002 | 10:39 PM
12SecHatch's Avatar
fmax kit coems with one
Old Dec 12, 2002 | 10:51 PM
Evs-One's Avatar
Solbros Owns Me
why not Z6 swap it
Old Dec 13, 2002 | 03:59 AM
Default Re: turbo a d series!?!?!? (Emerica)
why not Z6 swap it
the Z6 has a stronger block than the Y8 right ?
Old Dec 13, 2002 | 05:01 AM
del_sol's Avatar
i wouldnt spend the money on a pre fabbed kit. do a junkyard setup. I would suggest doing a 14b turbo out of a 1st gen dsm. Use the HF manifold out of a 92-94 civic cx. You will need an SMC, 450 cc injectors (1st gen dsm),resistors,fuel pump, thats the main ****. If you have good junk yards by you, or if you know people, you can get most of the **** for under like $500. If you dont have any connects, than just get the pre-fabbed...
Old Dec 13, 2002 | 05:02 AM
t0p_sh0tta's Avatar
why not Z6 swap it
Couple of people said this is bs.
Old Dec 13, 2002 | 05:05 AM
Default Re: turbo a d series!?!?!? (JDMDELSOL)
he would be better off with the Greddy kit, it's a direct bolt on kit and he want have to worry about using old parts everything will be new
Old Dec 13, 2002 | 05:32 AM
brcivic411's Avatar
greddy kit on my d16y8.
Old Dec 13, 2002 | 05:35 AM
Thirty-Nine's Avatar
Default Re: turbo a d series!?!?!? (brcivic411)
Stock internals? Was reliability compromised at all? I'd love to turbo my Y8, but it's also my daily driver and I need reliability …
Old Dec 13, 2002 | 06:12 AM
VTC_CiViC's Avatar
Default Re: turbo a d series!?!?!? (REVOEVOM)
why not Z6 swap it
Like me..
Old Dec 13, 2002 | 01:05 PM
Default Re: turbo a d series!?!?!? (Sushiboy)
you'll be ok at stock boost
Old Dec 13, 2002 | 01:09 PM
piscorpio's Avatar
Default Re: turbo a d series!?!?!? (VTC_boost-less_CiViC)
why not Z6 swap it
Like me..
basically the same right? Only the y8 has the better head.
turbo that D and be merry!
Old Dec 13, 2002 | 01:16 PM
Daniel's Avatar
i've got the GReddy 15G kit on my Y8. Type 31 FMIC, Walbro 255, blue box , and all at 5 psi of boost. about 7500 miles and still going strong.
Old Dec 13, 2002 | 04:02 PM
scdarksol's Avatar
I just supercharged my 93 del sol SI with the d16z6 engine, and vortech fuel rail, magnecore wires, zex plugs, missing link, intake, header, exhaust, centerforce stage 2 clutch. and to tell you the truth I am really disappointed by the performance of it, the car is faster, but not as fast as I was hoping. It feels maybe a little faster than a GSR. Go with a B-series and turbo. Just my opion.
lscivic8.5
Apr 20, 2007 01:17 AM
jdm_jeners
14
Oct 17, 2006 01:30 PM
LongSol86
Feb 22, 2006 09:30 AM
nickromeo
Feb 13, 2004 08:20 AM
hakemjmba
Dec 12, 2002 11:56 PM
