Turbo D series help/advice need!!!
Old Feb 19, 2006 | 03:55 PM
LongSol86's Avatar
Default Turbo D series help/advice need!!!
what do i need to do in order to put in the turbo kit for my sohc vtec with 115K milage on it. never turbo a car before so i need help.
Old Feb 19, 2006 | 08:56 PM
LSEGHATCH's Avatar
Default Re: Turbo D series help/advice need!!! (LongSol86)
What do you mean "put in a turbo kit?" I don't think you should be boosting if you bought a turbo kit and now don't know what to do with it.
Old Feb 19, 2006 | 09:27 PM
Azndude1983's Avatar
Default Re: Turbo D series help/advice need!!! (LSEGHATCH)
well.. kinda true that you should know what turbo is best for you car and how much boost you're planning to run. But i'm not being an *** like others. AS for D series (i've never turbocharged any D series but i guess it's kinda like B series. All Hondas Anyways, i'm assuming you got all the basic parts like Wastegate, BOV (not preferred but recommended). The hard thing about turbo charge is Air/Fuel management. You need to get you a Wideband 02 for accurate reading with like 450+ Injectors. I think D series aren't VTEC??? if i'm not wrong. Then you can get you a S-AFC1 or 2 for your piggyback system. But definately get that Wideband cause that **** will make a whole lots diff on making your car run right after installed the Turbo.
Old Feb 22, 2006 | 06:06 AM
LongSol86's Avatar
what is Wideband 02 ? i got the blow off valve, and its a SOHC vtec. 93 del sol si. do i need force piston and rods also ? trying to aim for around 200+ WHP.
Old Feb 22, 2006 | 09:30 AM
sohc_turd's Avatar
Default Re: (LongSol86)
A wideband o2 reads A/F, which is able to detect a 'wide' range. While the stock narrow band o2 sensor reads a very narrow range, stoich.
No, you don't need forged rods and pistons for your power goals. Try doing some research in the forced induction forum, but please do your own searching so that you can ask intelligent questions.
ahhwhat?
Northwest (Sales)
Jul 28, 2011 05:22 PM
albert
Jan 30, 2005 09:37 PM
