please comment on the condition of my spark plugs
i took off the sparkplugs of my turbo charge SiR and these are what they look like:
sorry about the pic but i think it's enough to see the condition of the plugs. i'm not sure what they really mean, am i running rich or lean? what should my plugs look like to be on the safe side?
by the way, are these normal resistance reading for plug wires:
#1 - 12+ k ohms
#2 - 10+ k ohms
#3 - 8+ k ohms
#4 - 6+ k ohms
is the resistance supposed to drop as the plug wires shorten?
[Modified by _Endless_, 3:10 AM 12/12/2002]
[Modified by _Endless_, 4:06 AM 12/12/2002]
#1 - 12+ k ohms
#2 - 10+ k ohms
#3 - 8+ k ohms
#4 - 6+ k ohms
Looks like the far left is rich and the other three are lean.
Man, do use a favor and change your avatar....she scares the **** out of me.
what cause the far left to be rich while the other is lean? by the way, the far left is cylinder #4 and far right is cylinder #1.
i don't have an injector on the intake.
here's my fuel setup:
vortech 8:1 fmu
bosch inline fuel pump
stock injectors
stock intank pump
i use the screwdriver test on each injectors and they all of them are ticking at the same rate. i thought i'll be ok once i installed the bosch inline but it seems there's not much improvement.
vortech 8:1 fmu
stock injectors
stock intank pump
how bout the spark plug wires, is it normal to have a lesser resistance when the wire gets shorter from cylinder #1 to #4?
cylinder#1 - 12.+ k ohms
cylinder#2 - 10.+ k ohms
cylinder#3 - 8.+ k ohms
cylinder#4 - 6.+ k ohms
