please comment on the condition of my spark plugs
Old Dec 11, 2002 | 06:08 PM
_Endless_'s Avatar
Default please comment on the condition of my spark plugs
i took off the sparkplugs of my turbo charge SiR and these are what they look like:
sorry about the pic but i think it's enough to see the condition of the plugs. i'm not sure what they really mean, am i running rich or lean? what should my plugs look like to be on the safe side?
by the way, are these normal resistance reading for plug wires:
#1 - 12+ k ohms
#2 - 10+ k ohms
#3 - 8+ k ohms
#4 - 6+ k ohms
is the resistance supposed to drop as the plug wires shorten?
[Modified by _Endless_, 3:10 AM 12/12/2002]
[Modified by _Endless_, 4:06 AM 12/12/2002]
Old Dec 11, 2002 | 06:38 PM
niedejb's Avatar
Default Re: please comment on the condition of my spark plugs (_Endless_)
Looks like the far left is rich and the other three are lean.
Man, do use a favor and change your avatar....she scares the **** out of me.
Old Dec 11, 2002 | 07:00 PM
_Endless_'s Avatar
Default Re: please comment on the condition of my spark plugs (niedejb)
what cause the far left to be rich while the other is lean? by the way, the far left is cylinder #4 and far right is cylinder #1.
Old Dec 11, 2002 | 07:01 PM
niedejb's Avatar
What kit are you running? FMAX?
Kill the avatar man.
Old Dec 11, 2002 | 07:09 PM
_Endless_'s Avatar
it's NOT a turbo kit coz a kit cost an arm and a leg from where i live. it's just a custom turbo.
Old Dec 11, 2002 | 07:10 PM
niedejb's Avatar
Does it use secondary injectors in the intake manifold before the throttle body?
Old Dec 11, 2002 | 07:11 PM
GraphiteAccord's Avatar
what your fuel setup? FMU? what injectors? stock? perhaps 3 bad injectors, and 1 good one...
Old Dec 11, 2002 | 07:15 PM
Cramerox's Avatar
Default Re: please comment on the condition of my spark plugs (GraphiteAccord)
sometimes flow rate of injectors can have that effect? maybe need to be balanced and cleaned.
Old Dec 11, 2002 | 07:18 PM
_Endless_'s Avatar
i don't have an injector on the intake.
here's my fuel setup:
vortech 8:1 fmu
bosch inline fuel pump
stock injectors
stock intank pump
i use the screwdriver test on each injectors and they all of them are ticking at the same rate. i thought i'll be ok once i installed the bosch inline but it seems there's not much improvement.
Old Dec 12, 2002 | 04:57 PM
_Endless_'s Avatar
how bout the spark plug wires, is it normal to have a lesser resistance when the wire gets shorter from cylinder #1 to #4?
cylinder#1 - 12.+ k ohms
cylinder#2 - 10.+ k ohms
cylinder#3 - 8.+ k ohms
cylinder#4 - 6.+ k ohms
SimplyTron
Oct 24, 2007 12:00 PM
SOHC_MShue
Jul 30, 2005 10:39 PM
92SiB18C1
May 28, 2003 04:30 PM
V3locity
Honda Motorcycles
Apr 3, 2003 12:29 AM
M.A.R.C.
Dec 10, 2002 04:47 AM
