d16y5 turbo - misses
Old Dec 10, 2002 | 05:34 PM
kamaleon's Avatar
Default d16y5 turbo - misses
i just got back my car from the shop it seems to run fine except that it misses every now and then, like a sudden and brief (split second) power loss.. what would this be? and how to fix it?
open to suggestions!
Old Dec 10, 2002 | 05:54 PM
HonaTek1's Avatar
Default Re: d16y5 turbo - misses (kamaleon)
The plugs might be gapped bit too much causing the spark to blow out during boost.
Old Dec 10, 2002 | 05:55 PM
HonaTek1's Avatar
I had the gap set to .035 running 15 lbs of boost and it was cool
Old Dec 10, 2002 | 06:08 PM
HXMan's Avatar
Does it do this under part throttle?? The Hx is a lean burn engine ya know...and all of the turbo parts you added may cause it to hiccup now....
Old Dec 10, 2002 | 06:37 PM
kamaleon's Avatar
Default Re: d16y5 turbo - misses (HXMan)
i gapped new ngk v power spark plugs to .44 which is the stock setting.. should i reduce the gap like urs? to .35?
"hickup" best one word description..
i have an a/f auto meter gauge, also my turbo timer reads and display o2 signl in volts. this reading is allways too high, like 2 volts + when it supposed to be under 1v.
hx primary o2 sensor has 5 wires
Old Dec 10, 2002 | 06:45 PM
kamaleon's Avatar
wouldnt the blue box fix the 'lean' burn stock hx?
Old Dec 10, 2002 | 06:58 PM
r4adkshn1's Avatar
http://www.ngksparkplugs.com/techinf...s/techtips.asp
read under gapping, good stuff all around though.
I run .031-0.032 with stock ignition & 8 psi.
Old Dec 10, 2002 | 07:05 PM
kamaleon's Avatar
Default Re: d16y5 turbo - misses (r4adkshn1)
8 psi? on what engine?
Old Dec 10, 2002 | 08:39 PM
r4adkshn1's Avatar
d16a1 (1987 integra)
Old Dec 10, 2002 | 09:38 PM
00TurboEX's Avatar
i would gap em around .28 or .30. works for me, and many others.
david
edit-thats if you have stock ignition.
[Modified by 00TurboEX, 1:39 AM 12/11/2002]
Old Dec 10, 2002 | 09:47 PM
BudaKai's Avatar
Default Re: d16y5 turbo - misses (00TurboEX)
A hic-cup would be caused be lack of spark. Detonation would be a lean burn condition. Yep, smaller gap needed
Old Dec 10, 2002 | 09:58 PM
kamaleon's Avatar
Default Re: d16y5 turbo - misses (tzsir)
yup, ignition is stock.. will try 35 first then go down if needed.
edit.. using blue box and wallbro 255 pump, fuel shouldnt be a problem
[Modified by kamaleon, 12:59 AM 12/11/2002]
Old Dec 10, 2002 | 11:31 PM
bretx0r's Avatar
the crossover from the economy mode in the d16y5 is a really noticeable jump and when im cruising at about 75 in 5th it is hovering around that crossover. It may miss once in a while
Old Dec 11, 2002 | 04:31 AM
BorderM3's Avatar
Pretty Sure the HX uses a 5 wire wideband o2 sensor...which operates off different voltage threshold than a standard o2 somewhere around 1-3 volts i think.
TravisBiggie
Jul 23, 2012 03:25 PM
civicsaremean
Jul 23, 2007 02:55 AM
vangc6780
Apr 9, 2006 04:35 PM
deanq4
Jul 11, 2005 08:24 AM
98lude-t
Jan 7, 2005 10:58 PM
