d16y5 turbo - misses
i just got back my car from the shop it seems to run fine except that it misses every now and then, like a sudden and brief (split second) power loss.. what would this be? and how to fix it?
open to suggestions!
Re: d16y5 turbo - misses (kamaleon)
Does it do this under part throttle?? The Hx is a lean burn engine ya know...and all of the turbo parts you added may cause it to hiccup now....
Re: d16y5 turbo - misses (HXMan)
i gapped new ngk v power spark plugs to .44 which is the stock setting.. should i reduce the gap like urs? to .35?
"hickup" best one word description..
i have an a/f auto meter gauge, also my turbo timer reads and display o2 signl in volts. this reading is allways too high, like 2 volts + when it supposed to be under 1v.
hx primary o2 sensor has 5 wires
http://www.ngksparkplugs.com/techinf...s/techtips.asp
read under gapping, good stuff all around though.
I run .031-0.032 with stock ignition & 8 psi.
i would gap em around .28 or .30. works for me, and many others.
david
edit-thats if you have stock ignition.
[Modified by 00TurboEX, 1:39 AM 12/11/2002]
david
Re: d16y5 turbo - misses (tzsir)
yup, ignition is stock.. will try 35 first then go down if needed.
edit.. using blue box and wallbro 255 pump, fuel shouldnt be a problem
[Modified by kamaleon, 12:59 AM 12/11/2002]
the crossover from the economy mode in the d16y5 is a really noticeable jump and when im cruising at about 75 in 5th it is hovering around that crossover. It may miss once in a while
Pretty Sure the HX uses a 5 wire wideband o2 sensor...which operates off different voltage threshold than a standard o2 somewhere around 1-3 volts i think.
deanq4
07-11-2005 08:24 AM
