just got done with tranny. Help
Old Dec 10, 2002 | 10:34 AM
spladam02's Avatar
Default just got done with tranny. Help
just got done dropping tranny and putting it back up and connecting and bolting everything. car wont kick over. whats the deal. any advice please. i go to start it and it just wont kick all the way over like its not getting gas or something. i check the distributor its getting spark. what could be the problem????? it was jacked up in the front pretty high for 4 days straight could that effect gas or antying.
Old Dec 10, 2002 | 11:38 AM
ImprtTuner88's Avatar
Default Re: just got done with tranny. Help (spladam02)
check make sure fuel is getting there. Is it spinning over fine and just not firing? Check plugs to see if they are fouled out............ I would check all this kinda stuff man.........
Old Dec 10, 2002 | 12:06 PM
94hondaLS's Avatar
yeah man. check you fuel delivery. turn your car to the on position and try to listen for the fuel pump to turn on. it should sound like a quiet buzzing sound. you can only hear it for a second though. if that works the next step is to see if your injectors work. get a noid light and unplug one of your fuel injectors place noid light across the connector and crank car. if light blinks inj. works. hope this helps
elite01
Honda Civic (2001 - 2005)
20
Nov 21, 2009 04:00 PM
Black 92
Feb 17, 2008 11:25 PM
turbocivic0618
Nov 24, 2005 08:20 AM
92awd4u
Sep 27, 2004 09:23 PM
Hondasaurs
Nov 2, 2002 07:21 AM
