help car wont start no spark no fuel or check engine light
Okay I bought a 92 honda civic lx for cheap because it wasn't running. The car doesn't have spark or fuel. I swapped the distributor from another civic and it still didn't have spark. I wired the fuel pump from the dome light and it kicks on. It doesn't have fuel otherwise. The check engine light doesnt come on when I turn the key nor does the oil light. Is that normal? If anyone has had similar problems or knows whats wrong you help would be greatly appreciated.
Modified by 92awd4u at 11:00 PM 9/26/2004
Re: help car wont start no spark no fuel or check engine light (92awd4u)
You need to write that better. Split everything up:
what works and what doesnt.
What does the car do or not do.
Stuff like that.
Stuff like that.
1. check all your engine ground connections. battery, thermostat housing, tranny, Alternator
2 Check your main relay.
3 Check all fuses and make sure they have the proper size fuse in there.
4. your ECU could be shot.
I swapped the ecu into another car and it works fine. Put the ecu from the other car into the non running car and it still doesnt run. Checked all grounds and they are all good. Any other ideas?
