just got done with tranny. Help
just got done dropping tranny and putting it back up and connecting and bolting everything. car wont kick over. whats the deal. any advice please. i go to start it and it just wont kick all the way over like its not getting gas or something. i check the distributor its getting spark. what could be the problem????? it was jacked up in the front pretty high for 4 days straight could that effect gas or antying.
Re: just got done with tranny. Help (spladam02)
check make sure fuel is getting there. Is it spinning over fine and just not firing? Check plugs to see if they are fouled out............ I would check all this kinda stuff man.........
yeah man. check you fuel delivery. turn your car to the on position and try to listen for the fuel pump to turn on. it should sound like a quiet buzzing sound. you can only hear it for a second though. if that works the next step is to see if your injectors work. get a noid light and unplug one of your fuel injectors place noid light across the connector and crank car. if light blinks inj. works. hope this helps
92awd4u
09-27-2004 09:23 PM
