Electrical Problem: My Kill switch gets HOT!
I have a fuel pump kill switch hooked up in my car (along with other theft deterants). I notice at times, during spirited drives, the switch gets LITERALLY HOT!
So hot its not able to hold at times.
What could cause this?
TIA --migs
TIA --migs
Heh, welcome to Highschool Physics
Take the following example: If you're trying to power some huge space heater, and have it plugged in to one of those $2 white Wal-Mart extension cords, it's going to get hot as ****. If you upgrade the extension cord to a higher gauge, it won't get hot. I'm willing to bed you're using a switch that isn't meant to handle anywhere near what you're putting through it. Go hit up Radioshack for a higher gauge switch
You could also consider using a relay with the switch, so that the full amperage isn't flowing through the switch itself, but rather through the more robust relay circuit.
Go hit up Radioshack for a higher gauge switch <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emsmilep.gif" BORDER="0">
and some higher gauge wire too <IMG NAME="icon" SRC="http://rely.net/~htimages/smile/emwink.gif" BORDER="0">
P.S. A better kill switch idea IMHO is to disable the main PGMFI relay. Its the gray box with the 8 wire plug bellow and to the left of the dash fuse box. The white wire is the one to disable.
Mike
Mike
Mike
Well, after months and months running the kill switch and getting hot. It finally failed on me this morning. I was driving 45-50mph down a road. My motor surges. It felt like I sucked in water. I thought I blew it but no way I could have because it was sunny as could be.
My car stalls but still rolls, I coast to the center lane. I had to rip off the switch and twist the wire together to make it start backup.
you meant thinner wire = more resistance, right?
Yes. I'm sure he realizes that now.
Well, people have said to use a thicker (lower number gauge) to reduce the heat. I think the problem is in my switch.
The wire is cool, its only the switch. Ill be getting a new switch
