is running open header bad for valves?
just thought i'd ask you guys b/c i've noticed many of you run open header at the drag strip. a guy i know said that due to back pressure or lack thereof, running an open header can cause bent valves. fact or fiction?
Neither.........
Crap, actually.
Running an open header can cause SOME vehicles under some conditions, to run overly lean, thus burning valves.
However, the ITR runs fairly rich as is. Doubt if the valves would burn unless other mods are involved.
John
Crap, actually.
John
My friend who races Ducatis once mentioned that a lot of motorcycle guys will put something over their tailpipe (he uses a cut tennis ball) to prevent 'cold' outside air from reaching the exhaust valves after a race (motorcycle exhausts are relatively short). The exhaust valves will, of course, be very hot after a race and 'cold' outside air has been known to slightly bend valves on occasion.
Personally, I have never seen this happen. But, that doesn't mean that it couldn't happen. I have no reason to doubt my friend. He is a very reliable source of information with plenty of experience.
Any motorcycle guys have any input on this?
-kenji
-kenji
yeah but we have a pretty long header. i doubt cold air will go all the way up.
then keep the car running
no i mean't that if the car is running, it will be pushing hot air out. since it's pushing hot air out, cold air cant seep in. which i said it in a joking manner
Please tell me how long you have to keep the car running to the point where the air coming out of the header is the same temperature as the air outside of the header.
-kenji
-kenji
Wouldn't it be pretty hard for cool dense air to displace the hot air that is present inside the header? I mean the hot air wants to rise. When the car is sitting still I see it is highly unlikely that cold air could get to the valves. IF it got to them it would no longer be cool because of the distance it traveled through the hot environment inside the header would have warmed it.
I would think the only way to get cold air to the hot valves would be if there was some sort of vacum sucking the cold air back through the header toward the valves.
On a race motorcycle I could see there being a problem. The headers are angled up, and the hot exhaust gases would escape out of the pipe allowing the cold air to sink down toward the valves.
Veil_Side_
Jan 9, 2002 03:06 PM
