Should I worry about the xtra 0.6:1 compression of my jdm b18c? Xtra precautions?
Old Dec 7, 2002 | 11:17 PM
BoostedGSRBubble's Avatar
Default Should I worry about the xtra 0.6:1 compression of my jdm b18c? Xtra precautions?
This will be my setup (thanks integra7)
t3/t4 from a drag kit
intercooler and piping from a drag kit
inline pro manifold
hondata IM gasket
skunk2 IM
tial wg @ 6.5 lbs of boost
3 in down pipe w/ flex
3 in thermal exhaust
vortech 12:1 fmu
walboro 255
hks ssq BOV
apexi boost and egt gauges
I wont be running that much boost and I know the intercooler helps out too. I plan on hondata and injectors but not for a month or so after the install. How much more "dangerous" is it w/ the jdm compression? Should I not boost until I can afford the hondata? I know nobody can guarantee me ill be safe but some reassrance or a firm "WAIT" would be nice.
Old Dec 7, 2002 | 11:37 PM
Tofurky's Avatar
Default Re: Should I worry about the xtra 0.6:1 compression of my jdm b18c? Xtra precautions? (trustsi)
you'll be fine. just keep the boost levels reasonably low. we have the same compression as USDM type R's. they have people running 6-7 psi on fmu's with no problems... just don't get crazy till you get hondata
you might want to look into a thicker headgasket if you're worried about that CR+pump gas...
i'm putting on the inline pro headgasket, which brings the CR to about 9.2-3:1 and plan on running 12-14 psi with a tuned hondata s200. daily i'll have it set at 10 or so.
but yeah, you shouldn't worry about it. you'll be a-ok
Old Dec 8, 2002 | 12:20 AM
ninesecrx's Avatar
Default Re: Should I worry about the xtra 0.6:1 compression of my jdm b18c? Xtra precautions? (Ruckus138)
I had a revhard turbo kit on my jdm gsr civic back in the day. Ran 9 pounds on it all day long with no problems. All it had was inline fuel pump and regulator.
Urugly
Jun 18, 2006 10:03 AM
HT Chaplain
Dec 20, 2005 07:37 AM
94TealGSR
Jun 5, 2003 08:54 AM
sonicSVT
Jan 17, 2003 09:27 PM
Markaccord95
Oct 29, 2001 04:32 PM
