Compression too high???...
Old Jun 17, 2006 | 08:10 AM
Urugly's Avatar
Default Compression too high???...
Hey guys...I already purchased some Arias pistons at 10:1 compression. This is for a turbo application. Drag Kit to be exact. I want to boost about 12 psi daily driven.
Did I get too high a compression piston? I was thinking with the Turbonetics Drag t3/t4 I could get it to boost a bit earlier.
Should I have just gone with a lower compression?
Any tuning issues I need to deal with at this compression or things to look out for?
Any advice is appreciated.
Thanks
Old Jun 17, 2006 | 08:21 AM
92SleepyHB's Avatar
Default Re: Compression too high???... (Urugly)
im running 10:5:1 on 14psi haven't had any problems yet
Old Jun 17, 2006 | 08:28 AM
Urugly's Avatar
what setup are you running...when does boost kick in??
If I am not planning on producing 400-600 HP, then is it really advantageous for any Daily driven car to run such a low compression??
I see everyone running in the 9's...
Old Jun 17, 2006 | 10:26 AM
purpleh22's Avatar
Default Re: (Urugly)
I'm running 10:1 Arias @ 10 psi on an H22. 12 psi on pump is okay. Make sure you have a good tune, AFR around 11.8 and timing about 20. A good engine mgmt. sys. is important. (Chrome, Hondata, Uber- etc.)
Old Jun 17, 2006 | 12:27 PM
urbansi's Avatar
Default Re: (purpleh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purpleh22 &raquo;</TD></TR><TR><TD CLASS="quote">I'm running 10:1 Arias @ 10 psi on an H22. 12 psi on pump is okay. Make sure you have a good tune, AFR around 11.8 and timing about 20. A good engine mgmt. sys. is important. (Chrome, Hondata, Uber- etc.)</TD></TR></TABLE>
Higher cp and boost is ok as long as you get decent gas in your area. 93 octance will work well with higher compression'd turbo cars just dont take anyones advice on where to set your timing at.
I have been going strong on 9psi and 10.4:1 cp for 2 years........ daily driven.
Old Jun 18, 2006 | 10:03 AM
Kruzen510's Avatar
I'm at 10.6:1 running 12lbs no problem either.
99siRACER
Jan 3, 2012 12:20 AM
slowcrx954
Nov 23, 2006 07:49 AM
TehMoonRulz
May 16, 2005 01:15 PM
simoh
Jun 30, 2003 04:25 PM
thinkbrianthink bu
Oct 13, 2002 10:47 AM
