Disappointed with Zex, should have gotten NX
Old Nov 22, 2002 | 04:45 PM
Alias's Avatar
Default Disappointed with Zex, should have gotten NX
I Recently installed a Zex kit on my 5th gen accord auto. I also have I/H/E and suspension mods. I'm running a 55 shot. I raced a all stock IS300 auto. He torqued braked and got me from the launch. When i turned on my nitrous i stayed at his rear passenger door. Well, i just wanted to share that with you guys.
Also, my car is running a little bit lean (my plugs are gray, not entirely white). I was thinking about getting a fuel pressure regulator and raise my fuel pressure so it would prevent me from running lean. Will this work?
Old Nov 22, 2002 | 04:57 PM
ForcedAccord's Avatar
Texas B*tch!
Default Re: Disappointed with Zex, should have gotten NX (Alias)
Get some colder plugs, that should have been the first thing you did after installing the Zex.
Considering that it was a 55 shot and you hung w/ an IS300, that's a lot better than what you had before. (not saying the IS300's are the fastest things out there, but definitely quicker than an Accord)
Old Nov 22, 2002 | 05:23 PM
Alias's Avatar
Default Re: Disappointed with Zex, should have gotten NX (ForcedAccord)
Yeah i already got the plugs (ngk brk7e's), i got them before i even got the kit.
Old Nov 22, 2002 | 05:46 PM
Stew Pidasso's Avatar
When your zex is activated. It automatically raises your fuel pressure to add more fuel. A FPR may make you run too rich and you will actuall ylose power. So when you are spraying you are not running lean. Go up to a 75 shot if you want more power. The kit does exactly what it says it does-gives you an extra 55hp.
Old Nov 22, 2002 | 08:03 PM
Alias's Avatar
yeah but zex is only rated to the flywheel. Also if i raise to a 75 shot how can i retard my timing? I've already tried with the stock distributor can it didn't retard by much. Should i spend the money and just get a adjustable cam gear?
Old Nov 22, 2002 | 09:02 PM
An adjustable cam gear will only adjust your cam timing, not your ignition timing. I have run a 75 shot and others have run higher. You only have to retard 4 degrees for a 75 shot. You should be able to easily adjust your distributor for that amount
Old Nov 22, 2002 | 11:24 PM
WhoNeedsVtec's Avatar
Default Re: Disappointed with Zex, should have gotten NX (Stew Pidasso)
what did u expect?
Old Nov 22, 2002 | 11:43 PM
KTeller8's Avatar
you can get a gear .. just buy one from me and that is one thing off your list. if your not fast then.. buy another thing. just keep buying till your fast enough
youll get there
Old Nov 23, 2002 | 03:47 AM
97hb's Avatar
Did you have a bottle warmer? 55 shot knocked off 1.3 seconds off my 1/4 mile times. Without the bottle warmer, its not the real shot.
Old Nov 23, 2002 | 04:34 AM
Alias's Avatar
Default Re: Disappointed with Zex, should have gotten NX (97hb)
No i didn't have a bottle warmer, that's probably another reason why i lost, i live in dallas and it's starting to get cold here at nights.
How are you able to retard you ignition timing by 4 degrees with the stock distributor? I tried that on my accord. The distributor on the accord is not like a civic, it doesn't allow much adjustment.
Old Nov 23, 2002 | 04:37 AM
Alias's Avatar
oh nvm i saw that you have a ignition kit
Old Nov 23, 2002 | 04:38 AM
Alias's Avatar
oh kteller8, do you ahve a website i can look at? Alot of ppl on this site recommended you.
Old Nov 29, 2002 | 10:37 AM
EuRoBrO's Avatar
A bottle warmer works wonders. I would reccomend getting a pressure gauge for the bottle also just to see what P.S.I. you are at. More pressure=More speed!
Old Nov 29, 2002 | 12:00 PM
2000Accord5sp's Avatar
Default Re: Disappointed with Zex, should have gotten NX (EuRoBrO)
Zex's 55hp increase is NOT to the flywheel. I have living proof.
I had ZEX on my '00 Accord...before zex, my car had 135hp to the wheels (5spd), and the dyno run with zex 55shot, i had 185hp to thw wheels...I loved the 55shot and it was enough to keep me happy for $450.
Note I DID have a bottle warmer though and usually kept the pressure at around 1000lbs if I was going to use it. On some hot summer days, the pressure got up to 1200lbs...that scared me. I don't know how much pressure those bottles can hold but...
Old Nov 29, 2002 | 12:02 PM
Accord94DX's Avatar
Default Re: Disappointed with Zex, should have gotten NX (2000Accord5sp)
my needle has been pegged @ 1500psi on really hot days. the bottle can hold 3000psi before the safety cap blows.
Old Nov 29, 2002 | 02:17 PM
GraphiteAccord's Avatar
Default Re: Disappointed with Zex, should have gotten NX (Accord94DX)
when i had my zex kit, it sucked without the bottle heater. once i got the nos bottle heater, that thing flew.
Old Nov 29, 2002 | 03:34 PM
scrubachu's Avatar
Default Re: Disappointed with Zex, should have gotten NX (GraphiteAccord)
ngkr 7's?? 7 is stock. you have to get colder plugs. i went down to ngkr 6's, and my zex kit was great. i couldnt get any traction until 4th gear.
Old Nov 29, 2002 | 03:48 PM
skud_dusty's Avatar
Default Re: Disappointed with Zex, should have gotten NX (scrubachu)
you also have to remember though that a dry shot is nowhere near as effective as a wet shot.
Old Nov 30, 2002 | 10:46 AM
Alias's Avatar
Default Re: Disappointed with Zex, should have gotten NX (skud_dusty)
I'm seeing alot of replys that my plugs aren't good enough. Alot of ppl recommened thed the NGK BRK7E's. What would u guys recommened?
Old Nov 30, 2002 | 11:58 AM
raceACCORDingly's Avatar
scrubachu:
no, stock heat range is 5. the bkr7e's are 2 steps colder. also you should have them gapped at around .035 not the stock .044, with nitrous you want a smaller gap. Nitrous is harder to ignite then NA, and the smaller gap is easier for voltage to jump across. The only time you want to run a gap as big as .044 with nitrous, is if you have an aftermarket ignition system.
btw i love my NX kit, and also a bottle warmer is almost as essential as the n2o in the bottle.
[Modified by raceACCORDingly, 9:05 PM 11/30/2002]
Old Nov 30, 2002 | 04:07 PM
97hb's Avatar
What??? How is a wet shot more effective than a dry???
Old Nov 30, 2002 | 08:28 PM
dvp95's Avatar
I lost 2 full seconds on a NX 50hp shot.
95greenlude
May 2, 2007 02:02 PM
live2ride31
Feb 4, 2007 07:39 PM
DA9kid
Jan 1, 2007 04:50 PM
JDMDC4life
Oct 12, 2006 02:18 PM
PowerSpeed Motorsports
Jun 12, 2006 06:05 AM
