Turbo Manifold Reinstall Scratching Noise Letting Off Throttle?
Old Apr 16, 2025 | 11:16 AM
tianathefrogcar's Avatar
Icon4 Turbo Manifold Reinstall Scratching Noise Letting Off Throttle?
Hello Everyone ,
I hope everyone is doing amazing.
I am looking for possible answers and/or ideas on next steps to diagnosis an issue I am having. Some time ago my dump pipe cracked before my waste gate. Went and got it welded and tried to install everything.
Turbo stayed in the car sitting on the exhaust, manifold needed to come off, turbo oil lines came off, wastegate pressure lines also had to come off. If you look at my photos below they may explain a bit better to what extent what was removed and installed.
- Put everything back on, cleaned all the parts metal met, 750 F sealant used on block and on the manifold, with one of the those 2 piece manifold gaskets sandwhiched in between. I also did the same thing with where the turbo meets the manifold, sealant on the turbo t3/t4 exhaust inlet, sealant on the manifold itself where it meets, with the t3/t4 metal double or triple grooved (dont remember) gasket sandwhiched in between.
- All headblots went in as tight as I could get them with copper antiseize, cant torque them because there is no way to get a torque wrench in. Thread locker on the oil line bolts onto the turbo housing itself, and on the 4 bolts holding the turbo inlet to the manifold as well.
- Did put a small small small amount of 750 F sealant on the gasket between the oil line to the turbo and the turbo itself, again the small plastic/fiberous gasket sandwhiched in between.
- wastegate pressure lines I made sure to put the correct lines for the top and bottom of the wastegate following the electronic boost controller diagram also below.
- If I missing anything please let me know, like any details I am forgetting about the install that could give insight please feel free to ask and I will clarify.
- Cleaned every gasket and meeting spot, alcohol, metal brush, blade, spent long time cleaning meeting surfaces and gaskets, etc.
- NOTE: Once everything was installed minus the oil line to the turbo, I poured 5-10ml x3-4 times into the turbo oil port, poured into the actual hole, not like injecting through that pressurized fitting itself, I didnt think that far ahead, perhaps this was my **** up, im not sure. But took the fuel pump fuse out (13) and poured oil turned it over a few times, again and again, towards the ends I noticed that the oil would no longer go down the hole in the turbo so that is when I assumed I was good to go, however when I was turning it over the few times I did, I wont lie the oil pressure never went above like 26psi. There was some oil pressure but again, I don't know if that has anything to do with the turbo or if I just fucked everything up, not sure.
Problem: By the time everything had been done, The sealants were on for like 3-4 hours, I know they are supposed to be on for 24 hours, but I just needed to know if I did this right so I am not sure if that is what fucked everything up. Anyways, the problem here is that when I let off the throttle the car makes a bad scraping sound, like metal scratching.
The sound does not happen when I am on throttle, the car was making normal oil pressure high mid 70s when it just started, and slowly came back down as it warmed up, only did a few pulls. But the scrapping sound only happens when I let off. Like maybe 1 second after I let off it happens. Car makes boost, all the right spools and blow off sounds, everything drove completely, normal, but as soon as I heard that sound I **** myself and drove it home and parked it. I maybe drove it 5 minutes total after it had warmed up for 5 minutes as well.
The sound happened in neutral as well and with the clutch in, again only when I let off and RPMs started coming down.
Soooo... what do you guys think the issue could be. I have been really short on money and I wanted to really take this install on myself to see if I could do it. As you can see I am not super mechanically inclined, but I did my best. When I get the time I am going to go back to the car and drop the oil and look for shavings- if the turbo is toast would I find shavings in the oil? And if there are shavings in the oil does that most likely mean my motor is toast too? Any help or direction would be really appreciated. I didnt notice any super bad smells or smoke coming out the back either, granted it was night time, but if you guys would like me to figure these things out and it could help find answers, even any other things, please I need help right now.
I have spent so much money on this car the last 5 years I have owned it, and finally this summer I wanted to drive it after fixing the dump pipe crack no boost issue, so please guys any help at all would be most appreciated.
overrev_it
Mar 27, 2009 06:54 AM
onelowchef
May 7, 2006 09:11 AM
b00sted4dr
Jun 13, 2005 01:52 PM
drift4food
Apr 8, 2005 05:07 PM
TurBoXBirD16
Jul 13, 2002 07:48 AM
