84mm possible on gsr sleeves?
Forgive me for my ignorance, but i am mainly a F/I guy. I know the largest bore you can go on stock sleeves with boost is 82mm and that is pushing it. I was told that 84mm overbore can be done on a N/A sleeve. I am about to build a gsr block and need to order the pistons, its between 81.5mm and 84mm. If anyone has the answer, someone in here will. Thanks in advance.
[Modified by boosted hybrid, 12:47 AM 11/19/2002]
what about 84.5? still cool? i think thats what IB is doing mine to.there a noticeable difference between 84 and 84.5 in terms of power or reliability or anything? any issues with it at 84.5?
with sleeves you can go up to 86mm N/A and be ok
with sleeves you can go up to 84mm F/I and be ok
Go with sleeves and 81mm just add boost to catch up to the 86mm guys hahaha
with no sleeves .20 over is it, I mean it if you want to keep your motor.
Im currently running AEBS sleeves with 81.5mm Ross pistons incase I pop it Im gonna go bigger bore (leave room for misfortune)
85mm bore with proper head gasket (cometic) and no more than 8.5:1 compression w/ 18psi boost daily driver... have sleeve support installed where GE does it ... and clamp with arp studs and moly not oil.
thats the closest I've come to push a customer's car ... she's still driving err kickin *** on the streets after 18 months. Oh yeah her car is faster than her boyfriend's pos FD ...
Greg
[Modified by CHEETAH, 6:44 PM 11/19/2002]
Greg
wow.. you can only sleeve a block to 84mm if you go with boost? Dammit! I guess I better chunk my 84.mm GE sleeved block and 84.5mm Wiseco pistons in the garbage
compwc18
May 17, 2005 05:37 PM
