1st ever build and desperately need some help.
Old Jun 1, 2023 | 10:56 PM
xebxkillinem's Avatar
Default 1st ever build and desperately need some help.
So this is my first ever build and I have no idea how to identify this problem. Car is a 99 civic lx, Motor is a d16z6. So I have built my motor from top to bottom, acl race bearings, eagle rods, arias pistons 76mm,
Brian crower valves, springs and retainers and a stock cam and stock y8 crank cause it’s all I had to put in it. All sensors are new and calibrated properly(checked with a volt reader), I changed all fuel components to match the z6 so I could cross that solution out, timing marks line up correctly with the cam gear and the pulley marks line up with the timing covers as it should. I wired in vtec and the 2 wire iac. My car idles properly, almost insanely good. Car takes off like a bat out of hell continues perfect acceleration in second but when I shift to third, fourth or fifth it just falls on its face and struggles to go. It almost feels like I changed gears to early but I can shift into third at 50ish mph and it still just falls dead on its face. I have changed all sensors and gaskets and torqued every nut and bolt to spec. Can anyone please give me a direction that I’ve not done.
Also, it is obd1 converted with a p28 and jumper harness on the distributor. Stock ecu as of now, turbo is coming once I make it run correctly.
Old Jun 2, 2023 | 07:19 AM
Chance EG's Avatar
Default Re: 1st ever build and desperately need some help.
So right now the turbo is not connected, and you're running NA correct?
What are you planning on doing for tuning?
Old Jun 2, 2023 | 07:47 AM
Sic_DA_Nine's Avatar
post a video
Old Jun 2, 2023 | 08:33 AM
Other than upgrading the internals it is stock. The ecu is a stock p28. My plans as of rn are just to run it N.A. stock until I get the turbo in about 6 months or so.
HondaHannes
Engine Machining & Assembly
15
Jan 5, 2020 07:34 AM
midorigreenmobi
10
Mar 30, 2014 03:42 PM
ef4real
Aug 3, 2012 07:57 AM
hondaeg6chue
13
Feb 14, 2012 05:58 AM
AVXHATCH
Sep 1, 2003 05:26 PM
