FuelTech remote tuners?
Wanted to know if anyone knows a good tuner for FuelTech? I'm running a very basic setup and just want to make the car drive able N/A before I go boost.
Thanks!
Thanks!
Jeff doesn't have Fueltech listed as one of his supported platforms, but I'd still ask him if he'd be available:
https://www.evans-tuning.com/etuning
Did you get in touch with them? I need a fueltech tuner as well. I've been working with fueltech tech support but my b18 turns over, but not start. If I give it gas while starting, it will start up but it's very lean. I need some help.
I did, and Jeff told me as of right now he has no plan of tuning on FuelTech. I ended up reaching out to a local tuner and they do. Waiting for them to get me a base map for the moment. I can ask if they can tune remotely if you want.
Yeah let me know, I just need the car to start and run, lol. Ill take it in for a dyno tune after the break in miles. Thanks man, and Iook forward and hearing from you.
Got it!!!!
https://m.youtube.com/watch?v=uL5GwayORoQ
I had to pull the valve cover and redo the mechanical timing, set the "crank index" to 180 degrees, and used a timing light for ignition timing while turning it over.
4genaccordfreak
Apr 7, 2013 04:33 PM
