strange window issue!?!?
hello all, 2004 honda accord 4 door. so ive had a problem with my rear driver window. I can roll the window down from the master switch, but i cant roll it up. when i go to the back door, i can roll it up and down with no problem. i was having issues with my door locks(keyfob stopped working, and the locks would actuate 3 times when i closed the door) and i found my original master switch has some corrosion.
i installed my master window switch, and i programmed my key, so locks are working as they should. still cant roll up the back window using the master switch. would it be a wiring issue? maybe corrosion on the harness, and thats why its not making good connection?
let me know your thoughts and ideas, thanks
If you replaced the master switch and there is still the issue where the rear left window cannot be raised from the driver's master switch, then there probably is an open (break) in the Brn/Wht wire at either the driver's front door jamb driver's rear door jamb. More likely the driver's front door jamb since that would be opened and closed the most.
The Brn/Wht wire send power (+) from the master switch to raise the driver's rear window. It runs from the master switch through various connectors to the rear.
SoL_ger
Nov 23, 2014 09:47 AM
hondagal2004
Nov 27, 2013 07:55 PM
haydenm315
Jun 22, 2011 05:46 AM
chris4x4
13
May 8, 2011 10:39 AM
