2007 Honda Accord windows/door locks concern
I am a Volkswagen/Audi technican and my expertise is limited to this concern. I am looking for Honda Technicians out there that know about any TSB's about this concern before I replace the master window switch. But if anyone else on this forum has had this concern before, feel free to comment.
Concern: The master power window switch is inoperative and door locks do not work with switch, only the passenger door lock switch functions. The key fob does not operate as well.
What I have done so far: Checked fuses, found fuses to be ok. Checked wiring and connectors, found to be ok. Re-programmed key fob.
What I ruled out: Window regulator, door lock actuator, fuses, wiring, window basic settings, and connectors.
I do not have All Data or access to wiring diagrams so I do not know whether or not the door lock switch and master window switch are on the same circuit and that the passenger switch may be on its own.
Found this thread, but does not apply. (for those of you who ask if i searched)
https://honda-tech.com/honda-accord-...-down-3037173/
Thanks in advanced.
Thanks in advanced.
This is a common problem with accords. I am really surprised there has not been a recall to fix the master switch. Keep digging in old threads. There are a few guys in here that knew how to solve without replacing master switch. The diagrams are posted in the thread.
Best of luck.
Best of luck.
Re: 2007 Honda Accord windows/door locks concern
Best of luck.
Best of luck.
Thanks in advanced.
Thanks in advanced.
JAD
13
10-01-2016 04:05 PM
H.N.F
05-18-2016 07:42 AM
mgerdes
10-23-2005 06:25 PM
