Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2004 Honda Accord 4-dr Front passenger window stuck in down position
Old 10-27-2013, 01:16 PM
hondagal2004's Avatar
Default 2004 Honda Accord 4-dr Front passenger window stuck in down position
I've searched through the threads and it seems that all of the posts I've found have to do with the master switch and NONE of the windows working. In my situation all but one window works, the front passenger side. It won't work from the master control on the driver's side nor the passenger side. The lock can be controlled from the switch on the side where the window won't roll up and when you try either switch to roll up the window, you can hear the motor trying to roll it up. How do I determine which switch needs to be replaced? Would the master switch still roll up/down the 3 other windows if it needed to be replaced? Would the passenger side switch still be able to work the door locks, if it needed to be replaced? Please help me out.
I wish the window was stuck in the up position but it's not. I read that I can roll it up using the battery but am not sure how this works and if it requires me taking the entire door panel off that's a non-starter for me.
Old 10-29-2013, 02:42 PM
Lost Again's Avatar
Default Re: 2004 Honda Accord 4-dr Front passenger window stuck in down position
Well, we are not going to make it too far if removing the panel is a "non-starter" for you
It "sounds" like the window motor/regulator has gone bad.....so the first test would be to pull the door panel and test and verify it?
Are you at least willing to pull the master switch from the drivers door? If so I can give you the "pins" to jump on it to see if the window moves.
Old 11-07-2013, 06:01 AM
It was a broken regulator. I paid someone to fix it.
Old 11-27-2013, 07:55 PM
asparkinthedark's Avatar
I was just about to post that I had a similar problem and it was the detached clip on the windows motor that caused the problem.
EndlEEsss
02-23-2023 03:46 AM
H.N.F
05-18-2016 07:42 AM
bassichonda96
06-22-2009 05:37 AM
berge
04-02-2006 09:59 PM
meshuga
12-01-2004 12:03 PM
Quick Reply: 2004 Honda Accord 4-dr Front passenger window stuck in down position
