I am troubleshooting a 2005 RSX with a K20A3 engine. I have found a couple of wiring connectors that seem boogered up and I'd like to replace them but I don't know what type or manufacturer these are or where I could buy replacements once I learn what they are. I deally I am looking for the plastic connector, the pin(s) that go with it, and a short pigtail of wire si I can cut a solder this into the wiring harness
Knock Sensor
Its a Female, Single Pin connector. It has " Y8 " molded into the back of the part of the connector assembly I need.
IMRC (Intake Manifold Runner Control) Valve Assembly
Its a female, 3 Pin connector and it has " Y01 " molded into the back
When I Google Y01 or Y8 wire connector I usually just get the metal wire terminal, I am hoping someone can point me to the manufacturer/type of waterproof connector that this K20A3 engine uses
Thanks in Advance
-manny Knock Sensor-Single Pin, Female IMRC intake Manifold Runner Control Valve Connector, 3 Pin Female
