Code 22 on 95 civic with y8 swap
Old Jul 12, 2020 | 06:44 AM
Preludejunk's Avatar
Default Code 22 on 95 civic with y8 swap
I have a 95 civic lx with a y8 swap using the stock non vtec harness, I wired the vtec pressure sensor to d6 on the ecu and grounded it to the thermostat housing and then the vtec Solenoid to a4 and I’m getting a code 22 for the vtec pressure sensor I’ve checked my wiring it all seems good I’m not sure what the problem is. Also I’m using a p28 ecu. Any help would be appreciated, thanks in advance.
Old Jul 12, 2020 | 09:46 AM
tony_2018's Avatar
Fish Twig
Default Re: Code 22 on 95 civic with y8 swap
Check oil pressure?
Old Jul 12, 2020 | 11:27 AM
muellersfan's Avatar
Originally Posted by tony_2018
Check oil pressure?
Also check whether the screen integrated into the VTEC solenoid gasket is clogged.
Chuck Smith
11
May 30, 2018 08:50 AM
Melissa52hgc
May 28, 2018 08:02 AM
seedlesseg4
10
May 21, 2014 05:00 AM
sedrohatchstyle
Apr 19, 2010 12:27 PM
ProjectEG8
11
Oct 28, 2007 01:00 PM
