I relocated my battery into the hatch in prep for a turbo kit install, GT 3076R, where I'll be using the stock battery box spot for a catch can. Added some shots to show how I approached with a circuit breaker mounted inside the battery box, running directly to the fuse box with a modified terminal fitting. I thought it came out pretty clean. Now I need to run the stock cables through some split flexible electrical housing to clean it up.
