relocating battery
Old Aug 23, 2004 | 06:01 PM
B18C_eg's Avatar
Default relocating battery
what are the rules at strips for relocating battery to trunk? more specifically a HB
Old Aug 23, 2004 | 06:06 PM
bomber's Avatar
Default Re: relocating battery (B18C_eg)
Battery cannot be relocated into the drivers compartment without a battery box (since you dont have a trunk you have no rear firewall, and therefore you would be relocating the battery into the drivers compartment).
So, get yourself an aluminum/nhra approved plastic box (moroso makes one I think?).
You will also need a master cutoff since the battery will be relocated.
Old Aug 24, 2004 | 03:13 AM
B18C_eg's Avatar
Default Re: relocating battery (bomber)
does it absolutly have to have a box or can i just use a tray and tie down? does it have to be vented outside the car? i have a NRG cell battery if that makes a difference
Old Aug 24, 2004 | 07:25 AM
ms1motorsports's Avatar
Yes you will need a battery box box that is sealed and vented outside the car. Also you will need a battery switch tho turn the electrical system off from outside the car. Moroso makes a nice sealed box for about $100. It doesn't matter if the battery is a sealed dry type. There are no exceptions to relocated batteries. All must be in a sealded box.
ryanevansoh
Jun 30, 2009 12:24 AM
Blown90hatcH
Apr 22, 2008 05:01 AM
4G92
Nov 12, 2007 09:32 AM
29psiHybrid
Feb 1, 2004 09:30 PM
Lo-Buck EF
12
Oct 23, 2002 08:56 AM
