B16B NOT PASSING NYS INSPECTION HELP
So I swapped a OBD2A B16B full swap into an OBD2B 2000 EX. I put a 99-00 si harness and ecu (P2T). I put a new oil pump with crank sensor. There are no CEL. Can someone please help me figure out why my car isn’t passing NYS inspection. Im so confused
No. They aren’t telling me why it’s failing. Before I put the crank sensor the CEL was in so it failed because of that. But a mechanic had told me that it was my ecu that needed to be switched. What other ECU can I run. Will a OBD2B Integra GSR ECU work?
This is bullshit, they ALWAYS tell you what you failed at. Did you go through the drive cycles to get the dtcs in 'ready' status? Do you have an obd2 scanner to tell if its ready?
Sorry for a delayed update, I did some work on my car and all my CEL are clear, my monitors need to be ready to pass inspection. I have a EVAP, CAT, and another. What is a correct drive cycle in order to ready them?
ST4TUS
Jun 22, 2007 09:10 PM
VinceVTEC
13
Nov 22, 2004 05:43 PM
