What's up everyone! This head used to be on an LS VTEC. I'm putting it back on a B18C now. I can't remember if this plug is supposed to be there or not? I know the one on the surface of the head needs to come out, but not sure about this one.
Yes, that one MUST stay in the head. If you remove it, you will not create enough oil pressure to lock up the VTEC rockers. Only remove the one facing the head gasket surface... and make sure that the plug is re-installed in the hole on the back right side corner that the external oil feed line was connected to on the LS/VTEC engine.
Thanks very much! After looking at it a bit more I figured if it was removed oil would come out there and wouldn't build enough pressure for VTEC to work. I definitely won't forget to plug the hole where the fitting was!
Next need to check v2v and p2v clearance and then pop it in!
