Knock that goes away while in throttle
Old Apr 8, 2019 | 12:04 PM
1320vickers's Avatar
Default Knock that goes away while in throttle
It’s d series 145xxx 5spd there’s a loud knock when idling that gets louder with a bit of throttle but when you get more content rpms it goes away to barley a tap oil is full added a little moly lube any help understanding would be appreciated
Old Apr 9, 2019 | 09:55 AM
Cody Pereira's Avatar
Default Re: Knock that goes away while in throttle
Can you post a video of the sound at idle? Being that the noise goes away, it helps to eliminate some possibilities, but it would help for anyone trying to help to hear the exact noise.
Old Apr 9, 2019 | 12:00 PM
It may have a slight knock but not as noticeable
File Type: mp3
Old Apr 9, 2019 | 12:10 PM
NukeNinja's Avatar
Bearing forces are highest at idle. An early bearing knock should go away at higher rpms.
Old Apr 9, 2019 | 12:26 PM
So where talking s rod bearing
Old Apr 10, 2019 | 04:38 AM
Agreed. Usually one of the first tell tale signs when there is an issue - found at idle.
OP, have you noticed any metal shavings (specifically brass looking) in your oil during a recent change? The tough part here is if it is infact a rod bearing, to catch it before it spins on the crankshaft is the key to a less-costly repair. my '95 D16Z6 spun a crankshaft bearing on the No. 3 connecting rod without warning after my oil pump failed and resulted in a full rebuild for me. I would recommend to change your oil to check and see if the damage is visible through shavings of any type.
Old Apr 10, 2019 | 11:53 AM
I checked it and don’t see and glitter looking oil the real odd thing is sometimes it goes away at all rpms Could I change rod bearings without pulling it
Old Apr 10, 2019 | 05:22 PM
Well, you can access the crankshaft by removing the oil pan and the oil pickup... that would give you access to the lower section of the connecting rods. You could "possibly" change them out from the bottom? Need to make sure that the crankshaft has not been damaged. Someone that may have done or tried this in the past may chime in, when I did mine I had the engine out of the car.
Old Apr 11, 2019 | 04:08 PM
I’ve rebuilt a couple of b series but I’ve necer had this problem I’d really like to take care of it without pulling
amtrak23
Oct 27, 2015 07:49 AM
RevrsOne
Other Make Vehicles
Aug 21, 2012 06:50 PM
sireg6
Mar 24, 2008 08:25 AM
SickIntegraWon
Apr 13, 2007 12:59 PM
xratedpres
Aug 11, 2004 09:54 PM
