Rod Bearing Noise
Rod Bearing Noise
Hi i was wondering if a rod bearing knock is a constant type of noise or a once and a while one?
When my car is at idle it is perfectly fine...nice and quiet...then when i rev it quickly it will knock for a second as i tap the throttle but be ok till i rev again...
Then when i drive it will only knock at low rpms then go away at higher rpm when i give it more gas...
As you can tell from what i described it only happens at low rpm...like 1000-2000 rpm...
Would this be a Bearing Problem or something else???
PS its not the Head...i had a valve job done less than a week ago...
1320vickers
04-11-2019 04:08 PM
Souls
07-15-2018 10:43 PM
amtrak23
10-27-2015 07:49 AM
