Help Me Please!!!
I have a boosted b20b civic coupe and when I pull out it’s fine but once my pedal reaches a certain point my car starts to cut out it’ll cut out between 4,200-4,600 rpm depending on how hard i’m Pressing my pedal in but if I apply light pressure then I can bypass it and go up to 6k-7k rpm’s until I reach a certain pressure on the gas pedal again and then it will cut when I got the car it was fine I pulled the trans out and welded my diff and threw it back in now that it’s in it cuts
Sounds like a problem with the tune, or possibly check your O2 sensor, MAP, VSS and TPS are all plugged in and working properly. What engine management are you on?
It kind of sounds like it i’m only hitting 5-6lbs I’d boost and the car is tuned on 10 but I checked and there’s no boost leaks anywhere I feel like it might be a sensor I pulled my tranny out and put it back in I feel like I didn’t plug everything in right
Time to upgrade to Hondata so you can log and troubleshoot.
luderone
Sep 30, 2003 09:14 AM
