Need help... Boost problems...
Old Jun 2, 2005 | 04:43 AM
busakiller's Avatar
Default Need help... Boost problems...
Hey guys.. I've been boosted for about 1 1/2 now.. My car has been tuned and i'm running a hondata S200b with a p28 ecu... The problem i'm having is when I start to go into boost my check engine light comes on and the car just hits a rev limiter like.. Soon as I let off the gas the light goes off and the car runs fine until it's under a load and it starts to go into boost... Can anyone point me into a direction to start looking for the problem.. Any help would be greatly appreciated...
Old Jun 2, 2005 | 04:52 AM
SoSlo's Avatar
Default Re: Need help... Boost problems... (busakiller)
sounds like an ecu problem did you chang programs iin your hondata??
Old Jun 2, 2005 | 04:56 AM
busakiller's Avatar
Default Re: Need help... Boost problems... (SoSlo)
I haven't changed anything... I suspect it may be an ecu problem too but I'm not 100% sure...
Old Jun 2, 2005 | 05:19 AM
busakiller's Avatar
Any chance that it could be a bad map sensor?? It's only when it starts to see boost it goes into limp mode..
Old Jun 2, 2005 | 07:49 AM
busakiller's Avatar
bump 4 some help on my issue!
Old Jun 2, 2005 | 04:12 PM
busakiller's Avatar
still needing some help...
Old Jun 2, 2005 | 05:03 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
MAP sensor? what amount of boost are you running? have you done anything to make the MAP happy under boost? or does the S200 cut the signal so the ECU never sees positive pressure? What code is it giving you? thats a good start!
Old Jun 3, 2005 | 03:25 AM
busakiller's Avatar
Default Re: Need help... Boost problems... (2000psi)
I was told on the Hondata as long as you don't boost over 10psi that you don't need to do anything with the map sensor... I'm only boosting 8psi... Now i'm unable to boost anything.. lol... Could a bad O2 sensor cause the car to do this?? I'm running a hondata s200b w/p28 ecu.. Or I'm thinking a bad ecu or something happen to the EPROM chip... Dunno know yet.... I don't think i'm able to pull the code because the cel light doesn't stay on.. It goes off after I let off full throttle...
Old Jun 3, 2005 | 07:31 AM
busakiller's Avatar
Bump again for someone that has heard of this problem and know how I can fix it...
Old Jun 6, 2005 | 08:22 PM
T4eg's Avatar
did the car ever build boost before? It sounds like the boost option isnt enabled.
Old Jun 6, 2005 | 08:23 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Need help... Boost problems... (T4eg)
could be a boost cut of some sort.
Old Jun 7, 2005 | 03:49 AM
busakiller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T4eg &raquo;</TD></TR><TR><TD CLASS="quote">did the car ever build boost before? It sounds like the boost option isnt enabled. </TD></TR></TABLE>The car has been boosting and has been tuned before... This problem just started happening... A lot of ppl are saying it sounds like the hondata boost option isn't working... I call Hondata which was kinda worthless.. They told me that I would need to take it to my closest dealer to have it checked out.. I'm from Pittsburgh, PA and probably the closest Hondata dealer is Columbus which isn't bad "2 hrs" but it's not where I took it to get tuned "Payntechnologies" in Michigan.. I don't feel comfortable driving 5 hrs to have someone look at the hardware and say yep the hondata box is bad... I was hoping to send my Hondata/ecu somewhere and have it check out to see where the problem is but thats not looking like an option....
nicktagz
Nov 2, 2006 07:54 AM
blackcrx16
25
Apr 14, 2006 06:35 AM
60-1teg
Jun 19, 2004 03:00 PM
MayhemSi
Sep 17, 2003 08:51 AM
TwistedHatch
Aug 3, 2003 08:40 PM
