VTEC Engage
Old Apr 2, 2019 | 06:13 AM
Phillip J's Avatar
Default VTEC Engage
Wassup Hondatech, So i'm having a bit of a issue here, a friend of mine has done a engine swap onto my car putting a JDM B16A2 in, The problem that i am having though is the car is not engaging VTEC at all not even at 5,500 RPM I tried going a bit higher around 7 7.5 but no sign of it.
Was wondering if anyone has had this issue before and what the main causes would be.
Also that my car aswell is Misfiring when it drives but fine in idle!
Any information regarding this would help alot thankyou!
Old Apr 2, 2019 | 06:57 AM
Krauthammer's Avatar
Default Re: VTEC Engage
if you're misfiring I wouldn't rev it high.... either way I think there is a safety feture in place NOT to engage the VTEC if there is a misfire. you can also check the screen on the seal for the solenoid, could be gunked up. also, you didn't say if the car had a vtec engine before the swap, if it didn't, what are you using as a vtec controller?
Old Apr 2, 2019 | 09:39 AM
09chaplak's Avatar
Loves Tossing Salad
As Ron would say, let's address the misfire first. Post codes
Old Apr 2, 2019 | 09:59 AM
2x0's Avatar
2x0
10 Year Member
What ecu are you using?
Old Apr 2, 2019 | 10:35 AM
tony_2018's Avatar
Fish Twig
Whose Ron?
Old Apr 2, 2019 | 10:44 PM
K20.ek's Avatar
What engine code you throwing?
Old Apr 3, 2019 | 03:33 AM
Phillip J's Avatar
I'm having a code 3 for Map sensor and i dont have one on, and apparently my mate was sayign that JDM B16A2s dont have one.. and im using a aftermarket ECU that is also apparently a spoon ecu
Old Apr 3, 2019 | 03:38 AM
2x0's Avatar
2x0
10 Year Member
Old Apr 3, 2019 | 05:03 AM
mk378's Avatar
With friends like that....
The ECU uses a Pressure-Density fuel mixture control scheme. A MAP sensor is essential to this scheme.
If it is a chipped ECU you need to look at the documentation for the chip and the tune.
Old Apr 3, 2019 | 05:24 AM
Phillip J's Avatar
Yeah man He fucked me over big time, apologies for the language if it isnt allowed here, Did you have snapchat, cause i can snapchat you videos of whats happening with my car being a bit more descriptive
Thanks heaps !
Old Apr 3, 2019 | 06:51 AM
K20.ek's Avatar
Put a map sensor in. It needs one to read air/fuel mixture.
Just because its a spoon ecu, it doesnt make it the best setup for your motor. Get one that’ll work for a jdm b16 so you can drive to your tuner and Get it tuned to your exact setup.
Old Apr 3, 2019 | 07:01 AM
K20.ek's Avatar
are you sure it’s JDM or USDM???
Old Apr 3, 2019 | 07:34 AM
2x0's Avatar
2x0
10 Year Member
There's no such thing as a JDM B16A2
Old Apr 3, 2019 | 09:33 AM
BiggieBert's Avatar
Loved
Community Favorite
you should never allow them near your car again. Clearly have no idea how to work on honda. And earlier B16a’s have a firewall mounted map sensor. Taht may be where rhe confusion is coming from.
Old Apr 3, 2019 | 03:22 PM
tony_2018's Avatar
Fish Twig
Originally Posted by 2x0
facepalm 100x.
Old Apr 4, 2019 | 04:35 AM
Phillip J's Avatar
I have photos of the engine bay i took earlier today guys if that also helps.
Old Apr 4, 2019 | 08:02 PM
Phillip J's Avatar
This is a better look at my engine bay!! Sorry i couldnt attach any photos for some reason.
Old Apr 4, 2019 | 08:03 PM
Phillip J's Avatar
I have photos but waiting to be approved by Admin! Thanks guys.
Old Apr 5, 2019 | 03:29 AM
2x0's Avatar
2x0
10 Year Member
Looks like a USDM B16A2 engine, but the intake manifold must be from a JDM B16A SIR-II which takes the remote MAP sensor. The vacuum port coming off the top of the throttle body should connect to it.
Old Apr 5, 2019 | 07:59 AM
BiggieBert's Avatar
Loved
Community Favorite
The rubber hose coming off the TB sitting on the intake tube MUST be connected to a map sensor, you will have to find a way to mount it or find the fuel filter/map sensor bracket (they go together) i can post a pic of mine if you need, or u can zip tie a map to something to secure. Second, i would remove the red cap on the black tube and put a little filter on it since it can’t reach the intake tube, this part is designed to draw fresh air into the engine.
Old Apr 5, 2019 | 08:01 AM
BiggieBert's Avatar
Loved
Community Favorite
Looks like a USDM B16A2 engine, but the intake manifold must ibe from a JDM B16A SIR-II which takes the remote MAP sensor. The vacuum port coming off the top of the throttle body should connect to it.
JDM manifolds don’t have the purge stuff, his does. Unless he added it.
Red1995egcoupe
13
Jun 14, 2019 04:26 PM
Bj Le Det
Jan 6, 2017 12:06 AM
Keir Gale
Jun 23, 2015 10:38 AM
JDMlyfestyle
Nov 13, 2003 01:59 PM
